compression release
Discussion in 'General' started by njbiker20088, Mar 16, 2017.
  1. njbiker20088
    njbiker20088 Active Member
    monroe nj 08831
    lsc iron horse, gold wing, 1500 intruder
    al
    I seen some people make a hole in the rubber boot and put wd40 is that true. and should I do that.
    chubs likes this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I did, but its a small slit not a hole, enough to get the straw to the WD-40 in it. Give it a squirt on the shaft and work it in.
    njbiker20088 and chubs like this.
  3. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    how long has it been since you did that and have there been any adverse effects?
    chubs likes this.
  4. njbiker20088
    monroe nj 08831
    al
    t/k I will put on my list to do when I can see grass all I see is snow .:oldwtf:
    chubs likes this.
  5. ground pounder
    ground pounder Active Member
    Ypsilanti,Mi.
    Big dog 2009 K-9 EFI
    Tom
    Again just get a hypodermic needle and syringe from tractor supply and fill with as much wd 40 as you need and just poke the small to medium sized needle through the rubber with the needle. Then your not making a slit or large enough hole for other debris or water to get into!!!
    #5 ground pounder, Mar 16, 2017
  6. njbiker20088
    monroe nj 08831
    al
    some say it helps them last longer ??? if it dose its a shot of wd40 is for me.
    chubs likes this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I usually hit them 2 or 3 times a year, and I've been doing it for at least 4-5 yrs, sometimes I can feel the carbon build up because its not smooth, so I work it with WD-40 until its smooth, No side effects because the slit is like the one on the tip of your wiener, and that don't let debris or water in now does it?:oldlaugh:
    I suppose you could get water in it if you directly hit it with a garden hose or power washer, but normal driving in the rain is not going to get in thru the slit.
    #7 BWG56, Mar 17, 2017
  8. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    did yo' momma drop you on yo' head when you was a little boy?????????????????? :oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::cheers:
  9. chubs
    chubs Well-Known Member
    laf. indiana
    runky
    Ha Ha Ha Ha,,,:oldlaugh: Ker said "Wiener"":oldwtf: :whoop: Giggle, Giggle !! :yesnod::oldlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh::oldhardlaugh:
  10. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    Guess you're not using a catheter yet! Good. I thought you would be at your age.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :oldlaugh: I can't say for sure, but something happened :oldlaugh:
    No catheter yet, but I do travel with my own personal nurse :oldlaugh: and I do like playing a very very bad patient :spank: :oldhardlaugh:
  12. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    He goes with the depends..:oldhardlaugh:
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Well that DEPENDS, no pun intended, on how far I'm riding:oldlaugh:
  14. njbiker20088
    monroe nj 08831
    al
    chubs and BWG56 like this.
  15. bdm7250
    bdm7250 Guru
    Doug
    Riding?..You can be sittin on your couch for a matter of five minutes and have an oops..:oldhardlaugh:
  16. chubs
    laf. indiana
    runky
    Just hope no one posts any pics of those new "speedo depends":oldwtf: :oldnono: that Ker is so fond of, for those fun rides on the spyder ! :oldlaugh: :oldhardlaugh::oldhardlaugh: ( just poking fun there Ker, Old Buddy :old2: ) :cheers:<- Non alcoholic beverage of your choice.
    Big D Florida and BWG56 like this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Hey my mamma always told me to put on clean ones when ya go out, ya never know when you could have, I mean be in an accident. :oldlaugh:
    Big D Florida, dentdude36 and chubs like this.
  18. chubs
    laf. indiana
    runky
    Just remembered, this thread is about a different kind of Compression Release !!:oldlaugh::chopper:
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    JR started to lead us astray this time, Wanker:oldrant::oldlaugh:
  20. njbiker20088
    monroe nj 08831
    al
    my mom to
    Big D Florida, BWG56 and chubs like this.
