Compu-Fire stator, rotor, and VR kit part #?
Discussion in 'General' started by bikepoor, Jul 13, 2016.
  1. bikepoor
    bikepoor New Member
    aiken SC
    2007 K9, 1973 electraglide, 1978 Honda 1000 cafe, 2007 Heritage, 1975 sporty bobber
    Joey
    Hi, my 07 k9 quit charging and I determined that the stator is dead! WSW is down till July 15th or longer as the website states and though I can find the kits none list big dog specifically! Thanks
    chubs likes this.
  2. bigd1960
    bigd1960 Active Member
    La Broquerie
    Mastiff 2007
    Daniel
    Have a bn vr and stator if u need. Purchased for my 07 as well.
    chubs likes this.
  3. bikepoor
    bikepoor New Member
    aiken SC
    Joey
    HI Tim, thanks for responding I am definately interested! Can you tell me more about what you have? Is it the rotor also? What brand and amp? Thanks
    chubs likes this.
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    BWG56 and chubs like this.
  5. bikepoor
    bikepoor New Member
    aiken SC
    Joey
    chubs likes this.
  6. Th3InfamousI
    Texas
    Original is 32 ..just standard Harley evo.
    Upgrade is to a 40..lot more $$
    chubs likes this.
  7. bikepoor
    bikepoor New Member
    aiken SC
    Joey
    I knew it was Evo but thought it was a different amp set up! I appreciate the info! I will order it today and get back to riding! Thanks!
    chubs likes this.
  8. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    chubs likes this.
  9. bikepoor
    bikepoor New Member
    aiken SC
    Joey
    wanted to give an update and say thanks for the help! i put the compufire 40 amp 3 phase on my K9 and it is working perfect! very easy install! i think it is awesome that guys on here are so willing to help and even offer their spare parts to get a fellow biker back on the road!
    PROFLYER, BWG56, chubs and 2 others like this.
  10. Bdm4ever
    Bdm4ever Well-Known Member
    Something Like K9
    Tony
    WTG BDB again..
    chubs likes this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :old2: Thanks for the update
    chubs and cdogg556 like this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Since I installed the voltmeter on mine I can watch the volts as I ride and was wondering what the big advantage would be to go to the 3 phase? I have 13.3-13.5 at idle, and anytime I'm going down the road no matter what RPM's its running at 14.3-14.4 volts. Now I realize its not Amps, but does the 8 additional amps really make that much difference:oldconfused:
  13. Th3InfamousI
    Texas
    Not a lick. Only difference with 3 phase is at idle it's like 14v.
    Extra amps are not needed on a big dog unless you got a stereo, heated grips and a bunch of other malarkey.
  14. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    :agree::old2::chopper:
  15. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    :old2:
    chubs likes this.
  16. Diesel powered
    Bay city, mi
    2009 bulldog bagger
    Jason
    can I use any 99 evo rotor; or will I have to grind the tabs? I'm not talking about a 3 phase, just 2 phase aftermarket replacement parts.
    chubs likes this.
  17. nosaj82
    nosaj82 New Member
    2009 Big Dog K-9
    Hey Guys.
    So I just installed my 40 amp on my 09 K9. Pretty easy task but I did not have to grind any tabs nor did I use any spacers and other parts that came in the kit except the rotar and stator.
    Did I install this wrong or is it possible that's its pretty much plug and play?
    chubs likes this.
  18. Th3InfamousI
    Texas
    Unless the bosses have been grounded down before the rotor wouldn't fit square without it. Actually I don't think you could get it on, unless you took off the inner primary as well.
    chubs likes this.
  19. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff
    Paul
    I have the factory charging system in my Mastiff but changed the voltage regulator for single phase compufire (after the oem one burned out) and at idle it I got 14.2 volts.
    Paul.
    chubs likes this.
