bfitz
So I'm installing the compufire stator, rotor and VR on my 05 chopper...stator is in place and I'm looking at the rotor...the new rotor is flat inside where as the one I removed was raised in the center..obviously for clearance...the kit I received from Curtis has a large thick spacer in it..I mean this thing is almost 1/4 (.250) thick..the obvious placement for this spacer is between the stator and rotor..but it seems a bit much .I know these kits can be generic and have a shit load of applications and I did see the post Jake did on the 40AMP upgrade but wondering if anyone has experience with this install. if so did you use the 1/4 spacer or?...really want to only do tis once...thx
