Dakota Speedos
Discussion in 'Technical' started by roadie1389, Jun 29, 2018.
  1. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Personally not a fan.
    Outdated to me. Reminds me of 80s cars.
    TapioK likes this.
  2. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I set my service interval to 2500 miles also. It reminds me to check my maintenance spread sheet for whatever might be due (usually just oil change). Once I perform the maintenance, I reset it.
    Unsprung and chubs like this.
  3. badyellowvette
    badyellowvette Active Member
    North Central PA
    2008 K9
    Jim
    I just hate my red one, can't see shit in the sun. I would much prefer a needle speedometer.
  4. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    I have heard that about the red. Nobody has said this is an issue with the blue. My bike is yellow/blue themed so the blue will go just fine.
    what? likes this.
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Blue is the way to go
    speedball jr. likes this.
  6. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    As long as there's no flashing red behind you it's all good!
    francoblay1 likes this.
  7. dentdude36
    dentdude36 Banned
    Upstate NY (suburbs of Buffalo)
    2007 K9
    kevin
    I love my blue one it makes the bike look more modern but I also do like the oem speedo I only replaced just to do something different the original worked perfectly and is now in someone else’s bike
  8. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    CC5422C5-CB94-4FB7-B07E-48B6C4AD42CD.jpeg A6E46041-4077-4AA7-A832-28DAAF4BD8C4.jpeg 1F3CFB41-D149-489B-81F1-D7995B5BB566.jpeg 68DEF04C-33C3-4004-B92E-6D715763854A.jpeg I got rid of mine all together.
    Steven Proctor likes this.
  9. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    How is the screen visibility in full sun? What about rain? What phone are you using? What App?
    Interesting Mount -- Did you make it yourself? Is it welded to the bars?
    I've been thinking about something along these lines myself, but thinking of using the speedo sensor and not gps for speed/mileage and more than likely "burning" a phone to stay in the bike sealed so that its watertight. Also considering using LED's for speed/mileage and using phone for GPS, MUSIC, TPS
  10. pknowles
    virginia
    paul
    Jwooky and Unsprung like this.
  11. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    I designed this in cad and 3D printed it. I use an iPhone X. No problem in full sun. I try to avoid rain, but these phones are pretty resilient.
    I use a couple different apps. The one shown is speedTracker. The one I find myself using most is actually waze. You can have a map with speed and music on top of the map.
    The best app I have used is actually Ulysse speedometer. Unfortunately for me it’s android only.
    I have it drilled and tapped into the bars. If you look at the pic without the phone you can see the embedded charging mat (the round device) and the two screw pockets adjacent to it.
    I also added LEDs along the bottom for neutral, L&R turn, Hi beam, oil, low fuel and EFI check engine. They are all hard wired to the bike.
    pknowles and Unsprung like this.
  12. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I can see a benefits I wish we had options that are not rectangular phones....
    chubs likes this.
  13. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    What did material did you print it in?
    What 3d printer do you use? I've got 3 myself, a cartesian, a delta and a corexy
  14. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    ABS. I’ll double check on what the printer it was.
  15. Nukeranger
    Luling, Louisiana
    Huw
    I'm thinking about putting an iwatch on one of the handlebar for some reason I can't explain :)
    TapioK and pknowles like this.
