Daymaker
Discussion in 'Customizing & Add-ons' started by Milco, Mar 4, 2018.
  1. Milco
    Milco The Flying Dutchman
    Petten Holland
    2007 K9 very orange, 2011 Streetglide CVO
    Milco
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Milco likes this.
  3. Mike manson
    Mike manson Well-Known Member
    Erie pa
    2005 bigdog ridgeback
    Mike
    Will they plug and play on ridgeback
  4. Th3InfamousI
    Texas
    Unsprung and Milco like this.
  5. Milco
    Petten Holland
    Milco
  6. Th3InfamousI
    Texas
    Milco likes this.
  7. Milco
    Petten Holland
    Milco
    Thank you!, and does this also solve the problem with the burned headlight connector?
  8. Th3InfamousI
    Texas
    The OEM plastic connector shouldn't melt as the current is much lower BUT I would still replace it when you got it apart anyways just incase. No reason not to put a ceramic one in the headlight regardless. Who knows once you get it apart it could have been replaced anyways already.
    francoblay1 and Milco like this.
  9. Milco
    Petten Holland
    Milco
    OK thanks again! I will look where I can purchase the ceramic one!
  10. HMAN
    HMAN Well-Known Member
    fk it
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Lamonster LED is
    1/2
    the wattage, no need for ceramic connector
    Element specifications (per element):6063 Aircraft aluminum construction.
    6000k color rendering.
    4000 lumen.
    360 degree light beam angle.
    24 watt per bulb.
    2.0amp (+/- .2) power draw. Stock halogen is 4.58amp.
    H4 connector for full plug and play operation.
    Daymaker,
    Mirror Lighting Type Headlight
    Voltage 12 volts
    Wattage 45.00
    dentdude36, francoblay1 and Milco like this.
  12. SCOTTx88
    SCOTTx88 Active Member
    Fredericksburg,Va.
    2004 Mastiff (Minus EHC)
    Scott
  13. Thejanitor000
    Thejanitor000 Member
    East Point, GA, USA
    2006 K9
    Darren
    Just ordered my Daymaker as well. $35 on Amazon.
    Reddickracing and pknowles like this.
  14. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    I ordered one today, and will be here Sat.
    chubs and Nukeranger like this.
  15. dentdude36
    dentdude36 Banned
    East
    :disappointed: Shoulda went halves on the best LED available for our bikes
    BWG56 likes this.
  16. SB03chopper
    St. Louis, Mo.
    Steve
    Go mine today, installed, looks great. Got the 2018 $42 one, chrome, and plug an play setup. Like the pattern instead of a full beam, lays with the land, gives more shoulder lighting.
    chubs and pknowles like this.
  17. Thejanitor000
    East Point, GA, USA
    2006 K9
    Darren
    Went out today and now I don't have hi or low beam lights. Waiting for the ceramic connector to come b4 I open it up & install the Daymaker. Hopefully its not a bigger issue. To be continued.....
  18. dentdude36
    dentdude36 Banned
    East
    Exactly the reason I tell everyone I meet with a big dog to change the bulb right away but they never listen
    BWG56 likes this.
  19. Thejanitor000
    East Point, GA, USA
    2006 K9
    Darren
    Wish I hadda known. We'll see what's up in a few days.
  20. Thejanitor000
    East Point, GA, USA
    2006 K9
    Darren
    All done. Replaced the plastic connector too with a ceramic one. Wish it wasn't raining......
