Dead Dog
Discussion in 'Wild Steed Worx & Services' started by CND Dog, Feb 10, 2019 at 4:17 AM.
  1. CND Dog
    CND Dog New Member
    Big Dog K-9
    I own an old 2006 K9, I ride it alot, 40K+ miles, always maintain my battery. Last time I rode it, I turned the engine off by turning the key instead of pressing the off button. Following week I tried to turn it on, nothing lit up, not the lights or any of the EHC led's. I did check the key switch and also removed the backbone cable and checked for ground loops, nothing there. Before I buy a new EHC is there anyone out there how can check it and see if it is really dead or is there something else I can do to diagnose it.
  2. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Ya, send it to me and I'll test it. call me tomorrow five 7 three- 2 fore 7- three 5 o eight.
    Big D Florida and SCOTTx88 like this.
  3. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I always turn mine off with the key switch. Is that bad?
  4. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    I never had a problem... and I do it very often.
    PacoPetty and SCOTTx88 like this.
  5. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    I do the same, never had a problem..
  6. drK-9
    drK-9 Member
    Wichita, KS
    16 Streetglide, 07 Softail Custom, 08 BigDog K-9, 07 BigDog Bulldog, LE
    Craig
    Reach down under the battery and see if there is a reset button...if so push it like you would a garbage disposal...
  7. JB105
    JB105 Member
    Wellsville Ny
    2006 K9
    Jeff
    And if there is a resettable relay there remove it and install a 40amp fuse block, those relays don’t work well and have been known to be wired in wrong. You should also fuse protect your ehc power lead to the battery
  8. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    That circuit breaker has nothing to do with not starting. It part of the charging system.
    TapioK likes this.
  9. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    First off you should locate an owners manual for your ride. The owners manual specifically states to always shut the motor off utilizing the "Off" button before turning the key off.
    Okay, having cleared that up, have you checked your battery voltage since this incident occurred to make sure your charging system didn't die causing the battery to go dead?
    #9 KaptinAmerika, Feb 10, 2019 at 4:41 PM
    chubs and 41bigdawg like this.
  10. 41bigdawg
    41bigdawg Let the Big Dawg eat !
    Portland, Tennessee
    2007 Big Dog K9, 2012 Heritage Softail, 2018 Honda 250 Dirt bike
    Robert
    Im glad you cleared that up for us first, Curtis...lol Always make sure you have your manual out before you start doing any maintenance :chopper:
  11. KaptinAmerika
    2006 Big Dog K9
    Curtis
    I wouldn't necessarily agree with that....lol. I only say that because I've found more than one BD with the battery lead connected to the same side as the VR and the remaining wires connected to the other side. Naturally, all things being connected correctly, it would not have anything to do with the breaker.
    chubs and Mr. Wright like this.
  12. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Thanks for the correction, you are right.
    chubs likes this.
  13. CND Dog
    CND Dog New Member
    Big Dog K-9
    Thx will do!
  14. CND Dog
    CND Dog New Member
    Big Dog K-9
    Totally agree with the manual, thats where I went first, and thought there should be a fuse but there was not, and the fuse on the charging system would not change anything as it is not in the power circuit of the EHC. My battery is always tendered even though I ride it every week end. I know that turning the key off with motor running was a mistake with those low voltage boards, that was a mistake on my part.
  15. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Thanks Franco and Doug!
    francoblay1 and bdm7250 like this.
  16. KnotSo
    KnotSo Admin
    Washington
    I turn bike off with the button sometimes and other times turn the key, seems to matter little either way. Bike is stock and still have the reset button with no worries.
    Follow the real world advice given by the other members and you will be good to go
    :chopper::chopper:
    chubs likes this.
  17. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Being somewhat stupid I never understood what difference it does in real life make weather one uses kill switch or key...
    RBennet, chubs and francoblay1 like this.
