Do I need a top end rebiuld?
Discussion in 'Technical' started by JeffM, Jun 8, 2018.
  1. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Who else could do it right? They should be the subject matter experts as they all worked for BD.
    If they are back they should know basic things like the Torque Specs for all the scoots.
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    they could probably put out a list of "recommended" standards and still be ok. that would go a long way in helping everybody out.
    chubs likes this.
  3. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Re writing a manual(s) takes a lot of time, time is money, a task specially for a small company. then we just share it free here and bitch if there is a mistakes left... Bad Combo
  4. BC200742
    BC200742 Member
    Lebanon
    Harley, 07K9
    Dave
    My Uncle once told me this is the only book you'll ever need for specifications on material, torque values, threads etc....
    If you want to do things correctly.
    #24 BC200742, Jun 25, 2018
    BWG56 and JeffM like this.
  5. pknowles
    virginia
    paul
  6. JeffM
    JeffM Active Member
    Australia
    Big Dog K-9 2008
    Jeff
    I rarely do nuts and bolts to tension by workshop manuals.
    As a mechanical fitter by trade i have an Engineers Hand book that has all the torque values for all metric & imperial bolts in all their various grades and thread types. I also do bolt stretch on some very big gear using dial gauges so i do have some idea in this area.
    Another point is "RED LOCTITE" should never be used on bolts under 1/2", the evidence is the 10 stripped bolts in my rotors.
    BLUE is the medium and with 1 drop will hold any bolt keeping our mobile jackhammers on the road.
  7. pknowles
    virginia
    paul
    Thanks for shedding some light on the subject.
    chubs likes this.
  8. kickstart
    TN
    Pat
    There are numerous torque charts available on the internet that list everything from types of material to class fit, run on torque, break away torque,dry and wet torque on and on. What I do is look at the recommended torque and start at about half and slowly work up to it however on occasion if it doesn't feel right to me I don't give it the recommended torque especially steel hardware into aluminum. There are several in the BD manual that are too high in my opinion. Just my .02 If it feels like it's about to strip STOP. :) That comes with experience and helicoil installation.
