Electric problem
Discussion in 'Help Wanted' started by bikeone, Feb 15, 2017.
  1. bikeone
    bikeone Active Member
    Bavarian Forrest / Germany
    Big Dog Pit Bull / Suzuki 1100 Streetfighter
    Hans
    Hi together,
    Think i have an EHC problem in my pit bull.
    malfunctions are brake light front - right side flashers - sometimes need decompression by hand.
    If engine runs, only one red intensive LED burns and flashes on the EHC.
    maybe a defect of front brake light sensor and a defect of the front flasher?
    cable Trouble?
    Good Tips how I can detect the malfunctions and where I get the necessary parts would be fine.
    regards
    bikeone
    chubs likes this.
  2. HMAN
    HMAN Well-Known Member
    fk it
    Start by checking all connectors. They must be tight and clean or filled with dielectric grease. Make sure your hand control switch's are not corroded or have broken wires. Be sure to check connectors between the tank also.
    Big D Florida, BadDawg Bill and chubs like this.
  3. bikeone
    Hans
    Will Check all connections this Weekend.
    EHC is on the way to an Electronicexpert for testing with big dog tester.
    The front brake switch works how? normal switch or short break?
    chubs likes this.
  4. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    Ok that was my suggestion to send out ECH to wildsteedworxs.com for testing.
    You do really need to check every connection you can find no doubt. Chaffing on a wire can be hard to see with dir and oil and hard to reach locations just need to take a little time. I f you pop off the gas tank there's a whole other world of connections there too. Jmo
    bikeone and chubs like this.
  5. Rottweiler
    Rottweiler Active Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    Look at you wiring dia. to see which wires to check then I believe the switch shorts to ground.
    #5 Rottweiler, Feb 16, 2017
  6. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    My suggestion would be, replace your EHC and harnesses with an ESC from DOC, and then ride the hell outta the thing worry free! :whoop::whoop::whoop::chopper:
    bdm7250, BWG56, bikeone and 1 other person like this.
  7. bikeone
    Hans
    Got new Iformation from my ehc.
    The ehc is tested - seems o.k. - only front light shows a mistake.
    But the front light works without any problem( Hi and low beam are o.k.)
    Strange - but he will send another one to me for test her in my pit bull.
    Would it be a good idea to clean the switches with Isopropanol (98%) and contact spray?
    Handlebar connection contact and ehc contacts are clean - like brand new.
    chubs likes this.
  8. bikeone
    Hans
    EHC is okay - brakelight switch and a defect flasher switch seems the mistake.
    We will see.
    Wait for the switches and my original EHC.
    Than I know more.
    Rottweiler and chubs like this.
  9. bikeone
    Hans
    Changed the switch board, right side now is new with new brakeswitch.
    Axel built the switchboards new for me. He builds programmable ehc s also.
    EHC functions can be changed with horn and flasher switches.
    All functions work - If i use the front brake now, the red and Neutral light glows up, when engine not runs and Ignition is off.
    Mounted the ehc on vibration killer - maybe a mass problem?
    Seems like the right rear flasher burns not so intensive than the other side.
    Will give separate Ground (Mass) to the ehc - case.
    Since I have and ride my dog, was this the only real defect.
    chubs likes this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Check 1 of the 4 screws that hold the right hand control board in place, particularly the head of the one closest to were the front brake reed switch is soldered on the pc board, if its touching, it could be shorting out.
    BadDawg Bill, bikeone and chubs like this.
  11. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    Also, welches rotes Licht kommt jetzt mit dem Leerlauf Licht an wenn Sie den Bremshebel ziehen?
    Sie können mir das alles gerne in Deitsch (Bayrisch) erklären, manchmal ist das umsetzen problematisch.
    Leerlauf Schalter und Bremslichter/Rücklichter haben den gleichen Erddraht.
    ......mir san a bayrische band.....
    Familie kommt aus Pöttmes, Nähe Aichach.....
    DBO.B, bikeone and chubs like this.
  12. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Yep what Mark said...showoff haha
    Big D Florida, chubs and Unsprung like this.
  13. Marky-Marc
    Des Moines, IA
    Marc
    Eric, my first language is NOT English...that is why I speak bad English....lol
    How's the mattress? I woke up at 4am again today....
    chubs likes this.
  14. Th3InfamousI
    Texas
    I know...juat giving ya a hard time.
    And your English is better than some who were born here. Lol
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I can see that :oldlaugh: :sorry: no I ain't, j/k
    should be nur :)
    Big D Florida and chubs like this.
  16. Eumel
    Eumel Member
    Germany Unterwellenborn
    09 Bigdog K9
    Helmut
    Das erklärt endlich einiges, vor allem den teuflischen Nachsatz...
    Wäre froh, wenn ich nur einen guten Bruchteil englisch könnte wie du, aber wir in Thüringen mussten damals als "Ostzonen-Deutsche"
    halt Russisch lernen - was für ein Graus, ich habe das immer gehasst. Nun ist man halt in dem Alter, wo man sich auch das Auffrischen der Englischkenntnisse erspart.
    Halt unsere deutsche Kultur in den Staaten hoch!
    viele Grüße von Eumel :cheers:
    chubs likes this.
  17. Marky-Marc
    Des Moines, IA
    Marc
    Nachsatz ist halt von einer alten Camel Zigaretten Werbung von den 80er.....hatte damals den Kleber.....neben meinem NENA Schrank Poster....
    Habs Abitur aber in Ludwigsburg am Marbach Schiller Gymnasium bestanden.....Schwäbisch kan i au......
    Wenn sie was brauchen, bin jederzeit erfüglich....
    Komme jedes Jahr zurück in die Schweiz oder nach 'Mingen'....hab noch Familie in München und in Starnberg...aber die meisten wohnen jetzt in der Schweiz.....
    Wenn ich nur russisch könnt....dann könnt i mir ne russische Frau 'kaufen'......
    Ab und zu denke ich, wenn ich in die s-Bahn in München einsteige, das die deutsche Kultur in den USA heutzutage mehr existiert .....
    Prost!
    chubs likes this.
  18. Eumel
    Eumel Member
    09 Bigdog K9
    Helmut
    Für die russischen Frauen brauchst Du kein russisch, sondern nur das nötige Money - aber kein russisches!!
    Das mit der deutschen Kultur ist nicht nur in München so...; das kann man so stehen lassen! :spank:
    Eumel
    chubs likes this.
  19. DBO.B
    DBO.B New Member
    Germany, Bavaria
    Big Dog Chopper 2005
    Dietmar
    Habe die Ehre Marky-Marc und Grüße aus Neuburg an der Donau.. sind ja nur ca 30km bis nach Pöttmes ... Hausstrecke wenn der Dog läuft ;-)
    ..ich probiers mit Denglisch wie de Lothaa gsacht hat ;)
    Servus in die neue Welt
    Dietmar
    chubs and Marky-Marc like this.
  20. Marky-Marc
    Des Moines, IA
    Marc
    Komme diese Jahr wieder....brauchst du teile? Kann sie im Koffer reinschmeissen.....vielleicht ein Gruppen Kauf für Deutschland/Bayern (Free Koffer Versand-hahahaha) .....wenn ich komme, trinken wir hoffentlich 'nen paar Pils oder ein paar Weißbier zusammen......wenn die Zeit es erlaubt...bin gerade daran ein Haus in der Schweiz zu kaufen (versuchen)......
    chubs likes this.
