Enclosed Trailer Size
Discussion in 'General' started by MossBerg590, Nov 18, 2018.
  1. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Im thinking about taking my ridgeback up to my brothers for christmas. Was wondering if anyone knew what size I should be looking at for 2 bikes. It would be the ridgeback and I'm trying to find my brother an 883 harley. Hes always wanted one and with what's going on I would like to try and get one for him. 883 are fairly small bikes, so would a 6x12 enclosed trailer fit both? Or would I need to try and find a wider one?
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I have a 6x12 Haulmark trailer and I can get my K-9 and my BMC 918 chopper (only 8ft long) in at the same time -- its a little tight but works.
  3. MossBerg590
    Arizona
    Tyler
    Do you use a wheel chock for both or just tie downs?
  4. MossBerg590
    Arizona
    Tyler
  5. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    Here is what I use.
  6. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    I have 2 condor wheel chock that I use plus tie downs.
    Should be able to do better than that -- seen 2017's for that price https://www.equipmenttrader.com/Tra...4681&model=6X12|764917113&layoutView=listView
    and that was a fast look
    check out this one. https://www.ebay.com/itm/NEW-6x12-6...m=392174254833&_trksid=p2047675.c100009.m1982
    MossBerg590 likes this.
  7. MossBerg590
    Arizona
    Tyler
    Ok thanks, I'll keep looking
  8. MossBerg590
    Arizona
    Tyler
    Both bikes are under 800lbs each so I dont think itll be overloaded at all
  9. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    My haulmark is around 1000-1100 pounds.
    When I had my K-9 and 918ST in and towing that was 1100+720+590 -- so I'm within the limits easily.
  10. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    A 6 x 12 should work.
  11. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    You can pick up wheel chocks at Harbor Freight for about $60. Then put blocks under the frame when you tie them down
  12. MossBerg590
    Arizona
    Tyler
    Thanks for the info everyone
  13. chubs
    chubs Guru
    indiana
    2002 pitbull Prostreet --
    runky
    I pull a 5 x 12 "v" nose with my 02 pit and kid brother's 06 K 9 . 2 round trips to Kansas to the anniversary get-togethers, and 2 round trips to Texas (without bikes, but loaded with furniture) with out any problems.
  14. SCOTTx88
    SCOTTx88 Active Member
    Fredericksburg,Va.
    2004 Mastiff (Minus EHC)
    Scott
    I've got a 7x14 v-nose that works great for a K9 and Mastiff.
    pknowles likes this.
  15. liferider
    liferider Guru
    Louisiana
    Jonathan
  16. liferider
    liferider Guru
    Louisiana
    Jonathan
    7’ wide or wider
  17. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Jonathon, I have to disagree -- that's the same size as my Haulamrk and I have had both my K-9 and my BMC 918ST in mine at the same time. Used it as a 2 bike garage for YEARS, taking the dog out very regularly.
    Granted there's not a lot of extra space, but it is doable.
  18. demon dog
    demon dog Active Member
    pittsburgh,pa
    08 ridgeback and 05 ridgeback
    craig
    I use a 6x12 v nose with harbor freight wheel chocks (altered for the fenders) and it works ok but if I had it to do again I would have went with the 7ft wide to better keep the mirrors and grips from the walls. And remember...,buy high quality ratchet straps with the sheepskin wraps for the front forks/triple trees.
  19. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    I have a brand new Doolittle 7x12 single axle, carries my 03 BD Chopper, and my 04 Honda VTX 1800R. Not overweight, pulls like a dream, and gives me room to work a round getting either bike out without removing last bike, as they are staggered.
  20. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    the trick to get a little more room for that is to stagger them a bit so the handle bars of one are in front of the other bars (since that's the widest point) the load front one first, back one second.
    that way you dont have to place the chocks exactly center of the half for each bike, you can slide in 2 inches and it gives enough space.
    But I agree, if planning on doing 2 bikes regularly get at least a 7ft wide trailer if you can afford it.
    Bigger is always better, well almost always.
    SCOTTx88 and pknowles like this.
