Enclosed Trailer Size
Discussion in 'General' started by MossBerg590, Nov 18, 2018.
  1. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Thanks, the 2 bikes would just be to take up to my brothers, after that I would use it for just the ridgeback and our dirtbikes etc
  2. geoffmt
    geoffmt Member
    Billings, mt
    07 bull dog efi
    Geoff
    I bought bigger than i thought i needed at 8.5x 20(16 ft deck, 4 ft v nose). it hauls 3 bikes, I use it for snow mobiles now, plus i can load the race truck in there too. Wish i bought it 4ft longer! Its well worth the purchase!
    SCOTTx88 and pknowles like this.
  3. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    when it comes to space, the old adage holds true: better to have and not need than to need and not have.
    SCOTTx88 likes this.
  4. 07bigdog
    07bigdog 07BIGDOG
    Winnipeg,Manitoba, Canada
    07 k9
    Ken
    You would be best off with a 7x14 trailer. Do not cheap out on chocks. Condor males one of the best. Drive in and get off the bike.
  5. demon dog
    demon dog Active Member
    pittsburgh,pa
    08 ridgeback and 05 ridgeback
    craig
    yep, got them staggered but still could use the extra room toward the walls
  6. MossBerg590
    Arizona
    Tyler
    I ended up getting a new Lark 6x12 V-Nose, was in my budget and will work good for what I need it for right now. Came with a 5 year warranty. So I'm looking at wheel chocks now, found one on Amazon and looking at the one harbor freight has. Opinions on which is better? Also with either of them will I have problems with the front fender on pivot part?
    https://www.amazon.com/Extreme-Max-...rd_wg=SzUEN&psc=1&refRID=XEG5PPWPAY8KH88Y1Y08
    https://m.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html
    Reddickracing likes this.
  7. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    Everybody seems to like that Biker Bar.
  8. MossBerg590
    Arizona
    Tyler
    Here's a pic of the trailer
  9. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
  10. 07bigdog
    07bigdog 07BIGDOG
    07 k9
    Ken
    The Condor chock makes an adapter for choppers that won't hit your front fender.
  11. MossBerg590
    Arizona
    Tyler
    The condor wheel chocks are all 200-300$ so I'm hoping someone has had luck with the harbor freight or Amazon one
  12. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Biker bar is about the same and worth it
  13. MossBerg590
    Arizona
    Tyler
    May be, but im not looking to spend $350 on a wheel chock
  14. demon dog
    pittsburgh,pa
    craig
    harbor freight chock works just fine...I cut down the cradle to allow clearance for the fender. you don't have to use the cradle if you always have someone to hold the bike while you're strapping it down because the straps are pulling forward. using the cradle works best when strapping by your self. makes no sense to me to spend $200-$300 for a condor when a $60 chock works just fine 001.JPG
    MossBerg590 likes this.
  15. MossBerg590
    Arizona
    Tyler
    Thank you
