Exhaust Question
Discussion in 'General' started by John Cingel, Mar 19, 2017.
  1. John Cingel
    John Cingel Member
    Parma Ohio
    2008 Mastiff 2011 Stratoliner deluxe
    John
    Have a 2008 Mastiff. It came with a 2 in to 2 vance & hines big radius exhaust without baffles. I ordered a pair of baffles and my question is Will I need to re jet carb after putting the baffles in.
    chubs likes this.
  2. ground pounder
    ground pounder Active Member
    Ypsilanti,Mi.
    Big dog 2009 K-9 EFI
    Tom
    Maybe. But you will only know for sure when you ride it a little. After you ride it and if its running good. Pull your spark plugs and see if they are burning the right color. If not then you will have to re jet!!!
    chubs and BadDawg Bill like this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    With the 2 into 2 Vance&Hines, they did come with bigger jets and if they were installed then, all you might have to do is readjust the carb. But you will be able to tell once you ride it if you have to adjust.
    Here's S&S's guide to carb adjustment if you need it
