First dyno
Discussion in 'Dyno Runs' started by Bhawkins854, May 10, 2016.
  1. MrDozerMan
    MrDozerMan Member
    STL
    Nick
    Then you shouldn't be spending $ on head work and such.......
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    chubs likes this.
  2. vej
    vej Active Member
    Land O Lakes Florida
    08 Mastiff Limited Ed.
    With those numbers... ever have any problems with your tranny? If we are saying a DSSC tranny is rated for 120HP, I'd like to know how yours is standing up. Just wondering. Thanks.
    chubs likes this.
  3. MrDozerMan
    MrDozerMan Member
    STL
    Nick
    No longer have the bike. It went a couple years ago when I had my 2nd kid. Tranny was fine but occasionally would pop out of 3rd or 4th gear. 1st and 2nd were fine. I'm sure it would have gone to shit in a matter of time.
    chubs likes this.
  4. Bhawkins854
    Bhawkins854 Member
    watertown,mn
    08 big dog mutt
    brendan
    I've been having issues with my trans...it's in pecies again, seems my cage bearing under 3rd gear is MIA. Do these transmissions hold after beefing up the case bearings?
    chubs likes this.
  5. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    What ? It isn't about money it's about fun but hey each to his own spend away :)
    chubs likes this.
  6. Diesel powered
    Bay city, mi
    2009 bulldog bagger
    Jason
    Patriot defender exhaust, bandit clutch and bearing carrier. Get it all for 1k. As for tranny; if Jim's has a kit. Do it. Otherwise. Rd in Florida can make ur tranny good for about 1700.
    Sent from my XT1254 using Tapatalk
    chubs likes this.
  7. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    A 2:1 will only give you 5 to 10hp, I know this from personal experience, pulled 115.43hp and 124.03 ft lbs with bid radius pipes. Changed to the 2:1's off my AIH got just over 122 hp photo is first pull, can't find my second pull results. This was with Woods 630 cam, S&S dual runner and minor head work, haven't done a pull since other upgrades. Have not had any issues with the Baker trans either, seems that they will handle 120+ hp, I'm sure this also depends on how hard you twist the right grip...
    chubs likes this.
  8. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    Not necessarily. Depends on what you're comparing it to.
    I know of some dual systems that make the same as a decent 2 into 1.
    John
    chubs likes this.
  9. Hammy
    Hammy Member
    Akron, OH
    2005 Big Dog Mastiff
    Brian
    Their website is HILARIOUS!!:D
    SKOGDOG and chubs like this.
  10. Mastiff Rider64
    Spartanburg, SC
    2006 Big Dog Mastiff
    Terry
    Hey guys just adding a little about the Transmission myth of the 120HP DSSC system since at this moment I'm having mine worked on. I recently (July '16) had my engine worked on had heads done, cam work, jugs, carb, whole top end built from scratch and all. My dyno run was 122HP and 134ft-lbs torque, at work now so no paperwork to prove that but that's what it was. But in Feb '17 after only about 1000 miles on new motor mods my front head went. Sent the motor to S&S Cycles to determine the root cause of failure. Come to find out workmanship. And of course the damage to motor is so bad they would rebuild it, but it would be cheaper to buy a new motor. So, I ended up buying a S&S V124, which comes with 128hp and I'm thinking 138ft-lbs torque. Well I seen the post by Curtis about the DSSC system. I contacted him and he confirmed the motor is to much for the trans, but said he is working on a fix for the problem but it may be a while. He suggested going to the new main shaft design and using the hardened shim, nut and washer. So, I called Baker and asked what can I do about beefing up the trans and the guy agreed with Curtis on the things he said to do, but the guy from Baker said the only issue you'd have after the trans mods would be my clutch assembly, because they too will not handle that HP. So, now I'm having to also install the Baker 2.4 Belt drive system. And with all the trans mods, baker belt primary that will make my trans good up to 130 HP. So the Baker guy has said I'll be walking a thin line depending on how I ride. So, guys with beefed up motors if your bike is older than '07 cause mine is an 06, and you've not went to the new shaft design, using the hardened shim, washer and nut to hold the clutch basket on your main shaft, your trans will eventually breakdown.
    francoblay1 and chubs like this.
  11. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    What was the purpose of the build are ya racing it?
    chubs likes this.
  12. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Well you didn't have to go with the baker open primary for clutch purposes.
    Bandit makes an upgraded clutch pack which would have handled the extra juice and would have only costed you 1/6th of the price.
    Not the open primary is bad...but just throwing that out there for others.
    francoblay1, chubs and lenny7194 like this.
  13. Big Daddy 72
    Bentonville, Ar.
    2006 Mastiff 2008 k9
    Big Daddy
    20 hp is a lot of power when your only talking about 120-130 hp total. On big v-8 making 650 plus, you might see that kind of hp difference going from a small primary to a large primary.
    The other thing is your dyno guy should have done some jetting and tuning. I personally think for what youve done to the motor you got some respectable results. Just like Eric said you dont race or ride dynos. Big Question is Are you happy with the tq and hp when you ride it.
    A good dyno tuner will be able to squeeze a little more out of and engine that most of us without one. Its a scientific aproach to tuning. It tells you when your tuning if your headed in the right direction. Me personally I dont really care what peek hp or tq is when I have something dynoed I just like using it as a tool to tune with maximum results.
    francoblay1, chubs and dentdude36 like this.
  14. Mastiff Rider64
    Spartanburg, SC
    Terry
    No wasn't racing it, I had actually had a valve seat go bad and egg shape the valve guide hole out and ruin the front head in May '16, so I figured since I was doing one head might as well do both, and since in 2011 I had the .600 cam already installed after having my motor switched from the EPA regulated motor (TP Heads, .545 cam, E carb) to the non EPA regulated motor (S&S heads, cam and a lot more) I wanted the performance the cam offered but the only way of doing this was to build the top end.
    chubs likes this.
  15. Mastiff Rider64
    Spartanburg, SC
    Terry
    Well I went with what Curtis and Baker suggested, Curtis knows these bikes inside and out. Plus I've always wanted an open primary this just gave me the reason to bite the bullet and just complete the bike the way I've always dreamed with a new motor (been wanting one since 2011), new open belt primary (wanted since I seen my first one on a dog 2007) and a rebuilt transmission (really didn't see this one coming but hey everything else was getting worked on why not), so hopefully I can get thru one riding season without any issues (knock on wood). lol
  16. Th3InfamousI
    Texas
    That's cool.. As long as you like it and I agree with ya they do look good.
    I knew Baker wouldn't recommend the Bandit clutch cause they don't make it.
  17. Mastiff Rider64
    Spartanburg, SC
    Terry
    Yeah but Curtis didn't recommend it either and I talked to him before Baker. But as many problems I've had with this bike since day one.... I'm just wanting to ride it, not look at it sit in the garage while I save up the money to get it fixed, and not pay someone work on it all the time (yes I know I could do it myself, but I'm an electrician not a mechanic). That last head job done in 2016 cost me close to $2500. And now dropping over another $10,000 on a bike blue book says is about $9,000. Not to mention the $3500 back in 2011 when I went from EPA regulated to non EPA regulated.
  18. chopperowner2478
    Oklahoma
    05 ridgeback
    Jay.
    Yep been there and every year I have routine repairs cause I ride it like i stole it... hard to be honest but after heads and tweaking mods everything else snaps and shows how weak and why hotrods love to eat up stock parts on mine...but I am old school and do my own... and love to work on it cause I ride YEAR round and it shows when I buy parts on a 1st name basis and fix it in a couple hours cause I have done it before.. lol but teaches me to chill out and stop popping front tire up and running from the loyal pd.... nothing like a chopper surrounded by baggers at bar and mine is diff.. and has no radio or anything to put a pair of sandals if I owned some lmao... L/R keep it simple...
    Spikes05, chubs and Mastiff Rider64 like this.
