Found a 2008 K9
Discussion in 'General' started by Nutzy, Dec 13, 2017.
  1. Nutzy
    Nutzy Member
    Bradford PA
    2008 Big Dog K9, 2015 Harley Davidson Ultra Classic Electra Glide
    Kevin
    I’m heading 95 miles North East this Saturday to look at a 2008 K9 with 6800 miles that’s for sale. It sucks we got 8” of snow today and I won’t be able to throw a leg over it for a few miles. And looking at the future forecast we have 15 more days of it so it’s here to stay for a few months! Ugh!!!
    Bolly likes this.
  2. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Hope it all works out for ya.
  3. Unsprung
    Unsprung Well-Known Member
    Ruskin, FL
    Gerald
    Good luck.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good luck and once ya get away from that lake effect snow you'll have clear sailin:old2:
  5. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Don't feel bad I have over 3 feet of snow and another 10-12 inches on its way
    #5 dentdude36, Dec 13, 2017
    PROFLYER, bdm7250 and BWG56 like this.
  6. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    I can only hope! Im taking the leather jacket and helmet just in case!
  7. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    I hear ya! You guys got hit hard in the last week. I’m heading to a town South of Rochester so I’m sure the have at least a foot or more.
  8. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    Will this be your first Dog?
  9. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    Yes it will be! For street bikes I started with a Honda then two Harley’s and I currently have an Ultra Classic.
    BWG56 and dentdude36 like this.
  10. Brandon Downey
    Anderson, IN
    Brandon
    If you get it, you're in for a real treat! I bought an '07 Mastiff back in August and my obsession with Big Dogs may or may not be unhealthy haha! Do your research on here though. There have been a few recalls such as side cover pins instead of bolts, a voltage regulator fuse, and be sure to ask about any wiring harness upgrades. I wish I had done a bit more research before buying (not that I wouldn't have bought it) just so I had a better idea of what to look for. Unfortunately I didn't learn of this forum until after I purchased. This is a really great forum with a bunch of guys and gals that really do want to help keep your Dog on the road.
    BWG56, Unsprung and dentdude36 like this.
  11. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    I don’t even own one yet and I understand what you mean about the unhealthy statement. I’ve been on this forum for several weeks now and I think I have read a lot of new and old forms for at least 2 to 3 hours a day every day! I’m obsessed with all of the information and knowledge.
    I’m aware of the wiring and old EHC modules giving guys problems, there’s tons of posts on that but I haven’t read anything on the side cover pins and voltage regulator fuse. Is this regulator fuse something that blows and is a one shot deal like normal fuses? I’ve read where guys are installing breakers, is this one of the applications there using these breakers for?
    Rottweiler likes this.
  12. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    came with breakers, replace with fuses. and as far as the side covers, would be a good idea to check to see if they have the pins into rubber grommets instead of the bolts into captured nuts. they tended to stress the corners of the covers and crack them or even break the corners off. pin kit should be available from bigdogpartsking (Derrick and Donna)
  13. badyellowvette
    badyellowvette Active Member
    North Central PA
    2008 K9
    Jim
    Hope it works out for you. You will have to bring it down to Smethport this summer so I can see it. Hopefully we could go for a ride.
    dentdude36 likes this.
  14. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    Good information, I’ll make sure I check and see what’s on it. It all makes sense to have the rubber to assist with the vibrations.
    Unsprung likes this.
  15. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    Yah for sure Jim. I have a few buddy’s I work with that live in Smethport. I either meet them over there and go for a ride or just pass through Smethport several times a year to head down through your neck of the woods!
  16. Brandon Downey
    Anderson, IN
    Brandon
    The recalls we have mentioned are very inexpensive to fix. $33 for the side cover pin recall kit and like $40ish for the voltage regulator fuse. So if they haven't been done on the bike, it's not that deep, it just might give you some negotiating ammunition :)
  17. Nutzy
    Nutzy Member
    Bradford PA
    Kevin
    Those are the prices I like! Great info!
    I know the new wiring harness and EHC module is around $750 from BD. If this hasn't been replaced hopefully it’s one of the dogs that hasn’t ever had electrical problem. I’m an electrician by trade so rewiring the bike is no problem but the cost can hurt the wallet. I’d rather put my money in accessories or modifications.
  18. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    If it has the original ehc your best and easiest option is axles ehc from elektronik box he really did a great job on building a true plug and play option and has a 2 year warranty
  19. Brandon Downey
    Anderson, IN
    Brandon
    I was told by the old Big Dog dealer here in Indy that if you buy 2007 or newer the electrical problems were fairly sorted out. I haven't had any issues with mine yet, but I know a lot of guys change it out for peace of mind. Isn't Axel's less expensive too?
  20. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    A bit less expensive and it has didfeeent modes you can set depending on preferences
