Front axle removal
Discussion in 'General' started by bushman, Nov 19, 2009.
  1. bushman
    bushman Active Member
    Boise, Idaho
    2005 Big Dog chopper,08 Ultra
    Just went to remove front axle on my 05 chopper so I can service my forks, and can't move the left axle bolt? There are 2 correct.Help needed
    Later, Wes
  2. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    you've loosened the pinch bolts have you?
  3. bushman
    Boise, Idaho
    Pinch bolts!
  4. bushman
    Boise, Idaho
    as you are sitting on the bike, the left bolt came loose somewhat easy, but the left one is a S.O.B.
  5. bushman
    Boise, Idaho
    Sorry the RIGHT bolt is a SOB
  6. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Bush, check out my "How To" on changing the front tire. It shows how it comes apart. I've also posted the schematics from the service manual in the gallery.
  7. narow37
    narow37 Angry Southern White Man
    Sherman, TX
    2007 Big Dog K9
    Shane
    there are two pinch bolts on the back side of the left leg from the front of the bike. they pinch the axle bolt and keep it from coming loose.
  8. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    #8 Raywood, Nov 19, 2009
  9. bushman
    Boise, Idaho
    Thanks for the responses everyone, when Lee said pinch bolts I went down to the man cave and investigated. It loosened right up after the "pinch bolts" were removed. DUH!
    Thanks Ray, I was looking at the manual for 20 min before I started,and still never noticed the pinch bolts.
    Again thanks everyone
    Wes
  10. narow37
    Sherman, TX
    2007 Big Dog K9
    Shane
    no problem, glad you found it, easy mistake.
  11. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
  12. lee
    Bristol, England
    :2thumbs:
  13. Ironmikey
    Ironmikey Member
    Sierra Vista, AZ. 85635
    2004 HD Dyna Low Rider; 2012 HD Custom Super Glide; 2006 Big Dog K9
    Mike
    Ditto Mega thanks for your info on rebuilding the forks (gasman, et al) and the pinch bolts on the front wheel axle. I had just put a long screwdriver and a rubber mallet on the work bench to pound that cotton-pick in' axle out when the idea fairy lighted on my shoulder and whispered in my good ear to check the Forum out first. SOOO glad I did..so is my BD K9!
    HMAN and pknowles like this.
  14. Ironmikey
    Ironmikey Member
    Mike
    Aaah! THOSE two 1/4-20 pinch screws at the bottom of the right (as sitting on bike) Lowe leg! Service Manual Page 2-90 Rev. B , left column, 4th paragraph from bottom of page!
  15. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    I wish that little voice would have shouted in my ear the first time I took mine apart.
    TapioK likes this.
  16. HMAN
    HMAN Well-Known Member
    Ks
    I wish the little voice had told me the bolt was already bottomed out before that last twist.... :( Bushing and left hand drill and I will get it removed. Shorter bolts will go back in.....
  17. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Use Stainless not Chrome on those pinch bolts there so it will only be a grade 5. Just so if it happens again it's a LOT easier to drill out.
    I actually think the manual states Stainless too...and only like 12 ft/lbs or something.
  18. HMAN
    Ks
    Yeah, the axle would not tighten up so I just kept cranking. I hope it drills out easy....ha!
