Front cylinder
Discussion in 'General' started by Herbert L. Williams, Mar 19, 2017.
  1. Herbert L. Williams
    Louisburg, N.C.
    2006 Big Dog Mastiff, 2015 Harley Davidson Ultra Classic
    Big Daddy
    chubs likes this.
  2. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    How did you check for spark?
    chubs likes this.
  3. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    I switched wires on the coil to switch cylinder heads and the bike wouldn't start. I switched back and it would only start using the rear cyclinder. I didn't have am ohm meter. It being Sunday didn't have much option. Any ideas how I can check it
    chubs likes this.
  4. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    did you just switch the plug wires or did you do the small wires that control when the coil fires.
    If you only did the plug wires the timing would be off drastically and I don't think it would start.
    PROFLYER, Big D Florida and chubs like this.
  5. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    No I didn't switch, which wires do I switch to this. Will it make the front cyclinder fire and the not the back
    chubs likes this.
  6. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Dang spell check and fat fingers. I only switched the plug wires, which wired on coil do I switch to test the front cylinder
    chubs likes this.
  7. Marky-Marc
    Des Moines, IA
    Marc
    Redneck way to check for spark with no tools:
    Pull front spark plug
    Plug it back into spark plug wire
    Ground spark plug to bike (fins or engine) with it plugged into spark plug wire off coil
    Hit start and see if it sparks or you get shocked....
    Yes, I've been drinking.....
  8. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I was thinking real redneck is your tongue
    Big D Florida, chubs and Marky-Marc like this.
  9. Marky-Marc
    Des Moines, IA
    Marc
    Well Eric, it is, I said redneck, NOT 'REAL' redneck.....bwahahahaha
    Cheers!
    Big D Florida, Alexey and chubs like this.
  10. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Okay let's say, I get spark, what's the next problem it could be? Without causing electrical shock, lmao
  11. Marky-Marc
    Des Moines, IA
    Marc
    Well, did it happen from one day to the next without any incidents? Or were/are there other issues before this started.....
    chubs likes this.
  12. Marky-Marc
    Des Moines, IA
    Marc
    Honestly, if you do have spark on the front cylinder and the rear is firing, but front isn't.....something may be wrong with your front cylinder......that's why I'm asking for more information.....
    chubs likes this.
  13. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    I rode one day, pulled some old led lights off from the previous owner. I saw a spark from a loose wire that touch the one or the other cylinder heads. I came back to ride a few days later and I noticed the front cylinder was not working anymore.
    chubs likes this.
  14. Marky-Marc
    Des Moines, IA
    Marc
    Then you have a short somewhere or a bad wire/ground, you just need to trace it down, I'm going to guess then That you will NOT have spark. If you saw where the 'spark' came from when the LEDs were removed, start there....
  15. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Is it possible, it shorted out the coil?
    chubs likes this.
  16. Th3InfamousI
    Texas
    Thats possible
  17. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    I thought you were going to say put your tongue on the spark plug wire... Ya, he has a short or a burned out coil. Seems to be a lot of that going on these days...
  18. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    check the three small wires going to the coil (not the spark plug wires)
    there should be a blue (rear) yellow (front) and red +12v going to the coil.
    If you disconnect the yellow and blue, you should be able to see spark if you ground the coil where the yellow/blue wire was on the coil assembly. This will test the coil. You could also remove power to the coil and use a DVM/voltmeter to measure the resistance of the coil on each side (red to yellow, blue to red) -- DO this OFF the bike or at least with the battery DISCONNECTED.
    I believe it should be about 3ohms if memory serves me correctly.
    If you don't have a voltmeter/DVM -- get one -- Harbor freight has them cheap -- frequently free or near free with coupon.
  19. Marky-Marc
    Des Moines, IA
    Marc
    You are correct, If he had a volt/ohm meter, this would be an easier task, hence the 'redneck' check with our without the tongue....lol......I'm sure he will invest in one soon.....
    You can also check voltage between the terminals with the coil still on.......
    BadDawg Bill and Big D Florida like this.
  20. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    BigDaddy, please post when you find the problem. Inquiring minds want to know!
