Front cylinder
Discussion in 'General' started by Herbert L. Williams, Mar 19, 2017.
  1. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Everyone should have a spark plug tester in your toolbox. They are about $5 at the parts store.
    You can do it the old school and ground to fins but the spark plug tester makes it easy.
    That and a multi meter
    Big D Florida and chubs like this.
  2. Dragonslave
    Dragonslave Active Member
    Salisbury, NC
    2004 Big Dog Pitbull
    Dustin
    HAH! Ive done this before. It isnt pleasant.
    chubs likes this.
  3. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    True, the manual trigger the coil really is another redneck or homebrew test I've used when the meter was in the basement and I wanted a fast test.
    If you own a Big Dog, you need a Multi-meter.
    chubs likes this.
  4. Herbert L. Williams
    Louisburg, N.C.
    2006 Big Dog Mastiff, 2015 Harley Davidson Ultra Classic
    Big Daddy
    Okay guys, I bought an ohm meter, checked the plugs, wires and coil, everything was with in tolerance. I spun the coil around and during the testing and fired the bike right up. Front cylinder working fine. Put it all back together, still worked fine. I rode it for 1.5 miles it strayed jumping and the front cylinder went out again. Thinking the problem is in the coil. Thoughts?
    chubs likes this.
  5. Th3InfamousI
    Texas
    Just curious is this an EFI or Carb Bike?
    chubs likes this.
  6. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Carb
    chubs likes this.
  7. Th3InfamousI
    Texas
    Well that helps! Makes it easier. We now know it's not going into any kind of limp mode
    And just to confirm you swapped plug wires yet? Just to see if you loose the back one instead? Just to rule out its the plug wire?
    You cant just swap the spark plug wires on the plugs themselves you will need to swap them on the coil since its a single fire coil front wire on coil has to go to front cylinder and vice versa
    chubs likes this.
  8. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Yes swapped the plug wires and run them on an ohm meter, no issues with the wires, it's almost as if I spin the coil over and it works fine. I reattached and runs on 1 cylinder after it spit and sputtered.
    chubs likes this.
  9. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    when you say - if you spin the coil over it work, but then reinstall the coil and it fails?
    SO let me get this straight - you pull the coil off the bike turn it upside down and move the wires front-back and it works.
    You then re=install and it fails on the rear cylinder?
    If that's the case it sounds like a broken wire/connector that makes the connection when its upside down.
    If you pull the coil and turn it upside down and do not reverse the wires what happens? Try jiggling them (one at a time) and see if anything changes.
    chubs likes this.
  10. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    On the verge of sounding stupid: Is the coil cover very close to or touching the coil wires?
    chubs likes this.
  11. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    When I say turn it upside down. I remove the 3 bolts and flipped the coil cover. I tightened all three coil wires, tested the ohms on coil, plugs, and wires. All three were with in tolerence. When I re-connected the coil cover and the bike ran fine for 1.5 miles the sputtered and went back to the rear cylinder only working. I am wondering if, it something inside the coil that is loose, or a kinked wire. The problem with the wire is the have an after market cover on them and I can't see. Really starting to get frustrated
    chubs likes this.
  12. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    It's down to a couple of choices.
    Coil is bad or something gets loose real easy when its in the correct position.
    Wire going to coil front cylinder is bad or shorting out when mounted.
    If you can reach the coil terminals without pull the cover - ohm them to ground and compare the front to the back. (Disconnect + on battery while doing this) Wiggle harness while testing. Given what started this I'm leaning towards the wire being bad going to coil.
    You also at this point might want to pull the tank off so you can do a visual inspection of some of the wires -- you might see the burn from the spark when pulling the LEDs off that you described as the trigger event. While its possible that its the coil, I'd bet against it and the ignition module appears to survived as well. It really sounds like a physical wire problem.
    chubs likes this.
  13. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Sorry for the lack of info on the spark, it spark against the front cylinder head. So I'm understanding correctly, disconnect the battery and using the positive ohm meter on the center (red wire) then touch the blue and yellow wire to check resistance. Then touch each end of the wires to the coil to check resistance of these wires.
    Then I do the wire inspection.
    chubs likes this.
  14. Big D Florida
    Troop Supporter Supporting Member
    I always thought this was a prank the older guys played on the newly initiated... Akin to peeing on an electric fence.
    :oldhardlaugh::oldwtf:
    chubs likes this.
  15. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Actually have you just swapped spark plug wires -- both ends -- pull front plug wire and make it back wire (from coil to plug) and use the old back wire for the front? Does it still fail front cylinder?
    Yes measure from the red to the yellow and blue -- that will check the coil
    The wire I am suspicious of is yellow wire in the harness that may have taken damage when the LEDs were pulled.
    The other test I'd do is pull the coil and cover off, turn it upside down where you say it runs.
    if it starts and runs on both wiggle the yellow wire a bit and see if the front cylinder drops out. (might need another pair of hands for this)
  16. Dragonslave
    Salisbury, NC
    Dustin
    I have done that before lol! Done it to myself first cuz I was too lazy to get the checker out. Needless to say I found my answer.
  17. Big D Florida
    Unless you're running some exotic, over priced plug... Just try another one....lmao
    chubs likes this.
  18. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    Okay I appreciate all the help guys. I pulled the tank and traced the wires as suggested. I found the coil wire connector under the tank. When I pulled the LED lights off. The fat fingers I have pulled the front cylinder (yellow wire) from the connector. I re-installed everything and took it for a ride and it worked. I appreciate I ate everyone's help. Esp. Since I have never worked on a motorcycle before.
    njbiker20088, BadDawg Bill and chubs like this.
  19. chubs
    chubs Well-Known Member
    laf. indiana
    runky
    We all knew ya could do it :yesnod::old2: Now wipe that embarrassed look of your face,:oldroll: and go enjoy the "fruits of your labors" :chopper: Stay Safe Big Daddy:old2::patriot:
    njbiker20088 likes this.
  20. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Hot Digady Dog :old2::old2::old2:
    ________:chopper:
    That was a nail biter for awhile.
    Good job people and thank for the info.
    chubs likes this.
