Front Fender Alignment Question. 08 Ridgeback
Discussion in 'General' started by Kobi, May 16, 2018.
  1. Kobi
    Kobi Member
    Full Member
    Josephville MO
    2008 Ridgeback
    Kurt
    I just replaced my front tire and noticed the lower rear edge of the front fender is kicked over to the left. I had not noticed that before. I can see that the original tire was rubbing the inside of the fender slightly in the past. I loosened the four bolts that hold the fender braces to the fork tubes and I got a little more clearance but not enough to center it. Any suggestions? I did not touch the bolts that hold the brace to the fender in fear I may hurt the paint. I have a heavy 1/8" gap now on the rt side, it was tighter.
  2. pknowles
    virginia
    paul
    I would try to loosen all the bolts and push it to the right all the way and hold it while snugging the bolts and see if that helps. It cant hurt
    #2 pknowles, May 17, 2018
  3. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Funny cause I have been look'n at my front fender at the top and it's off center and I can't remember if its always been that way or not, bugs the hell out of me and no matter what I try it won't center on the wheel, freak'n weird!
    BWG56 likes this.
  4. pknowles
    virginia
    paul
    Post a picture from the top if you can
  5. pknowles
    virginia
    paul
    Have you had your forks off
    cdogg556 likes this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's odd:confused:
    cdogg556 and dentdude36 like this.
  7. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Yep, I did the fork seals, but it all only goes together one way, I did loosen everything and compress the front end then tightened everything while compressed, I've done it without compressing it, I've tried everything and it will not center on the front wheel, I've come to the conclusion that it was that way originally and I never noticed it.
  8. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    :disappointed:
  9. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Yea that's kinda hard to do by yourself so I used my tie downs up against my truck bumper to do it, actually worked pretty good.
    dentdude36 likes this.
  10. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Yea it sure is ain't it! :skep: :oldsmile:
    BWG56 and dentdude36 like this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :old2:I do believe BroHolmes, your right:chopper:
    dentdude36 and cdogg556 like this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good thing ya didn't get distracted and drive off in the truck:oldlaugh:
  13. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Thanks bRo! :oldsmile:
    dentdude36 and BWG56 like this.
  14. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Yea, dat wuda bin weel funnay! :oldeek: :oldlaugh:
  15. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Anyways back on the original topic, maybe some of you hosers could post sum pics of you spacing on your front fenders to see if they are perfectly centered or if they are off a bit, thanks.:)
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Its still stuck in the drywall from trying to center it, I didn't realize I was between the studs when I gunned it.:oldbang:
  17. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    :oldeek: :oldhardlaugh::old2:
  18. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    Try checking the distance between the lower tree and the top of the dust caps. Being off might possibly torque the fender a little.
