handlebars (newbie question #1)
Discussion in 'Forks / Handlebars' started by angelofinsanity, Mar 17, 2009.
  1. angelofinsanity
    2008 pitbull
    so ive been looking to customize my dog (before ive even recieved it) and im curious about handlebars. my bikes a 2008 pitbull. ive seen quite a few dragbars i like but from what i understand big dog controls and grips are a very akward size (1 1/8inch i think?). so that means i have to get bars custom made in order to use the stock controls and grips, or i can buy some bars for a harley but i have to buy new grips and controls (standard 1inch)?
    is my theory right or could i conceiveably still use the stock stuff on aftermarket bars that have a 1inch area for grips and controls?
    chubs likes this.
  2. V
    V Guru
    The BDM is set up with a low voltage system to the controls so you can't use harley or other style controls on the bike. You'll get more answers though:D
    chubs likes this.
  3. LDO
    LDO The Cleaner
    P-Cola FL.
    03 Mastiff
    Depends on what you're after. You want new bars or new controls? You can have new bars (I would get them custom made like Moespeeds did). Use your stock proprietary controls though. Personally, I wouldn't mess with the electrical system on your new Dog.
    chubs likes this.
  4. titus722
    titus722 Active Member
    Home
    2006 RIDGEBACK
    3 can keep a secret if 2 are dead
    i put chopper bars on mine,,got them used ,a new set was almost 500 bucks,,,
    chubs likes this.
  5. luckydog
    luckydog New Member
    08 big dog k-9
    i have a 08 k-9 . need handle bars . who can help me
    chubs likes this.
  6. PSI GERMANY
    PSI GERMANY Active Member
    Palm Beach
    Big Dog K 9
    PETER
    Luckeydog,
    I have a '07 K 9 and wanted higher bars, look for my post somewhere here on the forum - with pictures.
    Big Dog recommended 06 bars from the Mutt (3.5" higher, 1" more forward).
    It is now perfect for me. No other changes necessary - electric cables are just long enough, same for clutch and brake line. BDM installed all the wires in the bars before they send it, so it was a very easy installation. Very happy with it and no electrical issues.......:) :) :) :)
    chubs and BadDawg Bill like this.
  7. Moespeeds
    Moespeeds Well-Known Member
    Cherry Hill, NJ
    2004 Big Dog Chopper, 2011? Redneck Monoshock, 2003 Roadstar Midnight, 2000 Roadstar Custom
    It depends on how much aggravation you are willing to go through. You can have bars made the same size as BD bars, I think it's 1 1/4". Or you could get 1" bars and have sleeves machined to take up the difference. Unless you go with a similar rise and pullback, you may need to extend your wires which would be a hassle. Bottom line is unless you goto another set of BD bars, it's going to be a pain in the ass.
    chubs likes this.
  8. tpir33
    tpir33 Member
    Kansas
    05 chopperdt,07 Ultra Classic
    you can put the stock controls back on as long as you get 1.25 bars. put a sleeve in the throttle grip. on the clutch side you will need to fill the 1/8 gap with something. and new cables if needed. the switches are tricky I just did this on a 04 mastiff. check it out.
  9. wheelndeal
    wheelndeal New Member
    '04'Big Dog Bulldog
    I cut my original bars where the controls are and lug welded them into a Carlini handle bar. The Carlini bar was also cut to keep the original dimensions.
    I rechromed the Carlini drag bar after the mod.
    Jarrod Lehman likes this.
  10. stlmikie
    stlmikie I wish I had more money.
    St. Peters
    03 Mastif
    Mike
    Well lets see it Mr. No Intro.
    chubs likes this.
  11. mobsta
    mobsta Well-Known Member
    O4 MASSTIFF
    joe
    handlebar change
    i had some sleeves made from aluminum by a friend.this way you can use any bars you want and still use your bd controls.
    chubs and Jarrod Lehman like this.
  12. Jarrod Lehman
    Jarrod Lehman New Member
    wichita ks
    08 pitbull
    Jarrod
    Do you have pics of your bars? Thinking of doing the exact same thing...I've got an 08 pitbull with dragbars, looking at Carlini's 14" panty droppers, I love the look of them. Hope they'll be comfortable!
    chubs likes this.
  13. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    I couldn't imagine 14" apes would be comfortable at all, you'd be laying on the tank to reach far enough forward.
  14. pauldeepsea
    pauldeepsea Well-Known Member
    California
    2004 Pitbull/ 2006 big bear sled 300
    Paul
    The post you are replying to is from 2009. I don't think these guys are still a part of the forumn. Good luck
    chubs likes this.
