Harbor Freight Lift $299.99
Discussion in 'General' started by Rottweiler, Jul 10, 2018.
  1. wildbill7638
    wildbill7638 New Member
    fatboy
    Frank
    I’ve been using one of them for years
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Here's mine and I went overboard.....I added 4' Angle Iron extended it 12" and the condor wheel chock. I also had to shave it down 1/2" as well even with their chopper one. Problem is if the bike moves just a hair that's when the fender hits.
    I've also bolted the free Harbor freight magnets to the sides so I can clean up the table and put the wrenches and sockets on them when working!
    Great table and I swear I've seen a $279 coupon recently but maybe that was a July 4th sale or something.
    #22 Th3InfamousI, Jul 11, 2018
  3. 41bigdawg
    41bigdawg Let the Big Dawg eat !
    Portland, Tennessee
    2007 Big Dog K9, 2012 Heritage Softail, 2018 Honda 250 Dirt bike
    Robert
    Thanks everyone...that was a lot of great input. I will be adding one of these to the shop...maybe 2
    PacoPetty, wildbill7638 and chubs like this.
  4. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    There is always a 20% coupon.
    Sent from my LG-V940n using Tapatalk
    PacoPetty and Nukeranger like this.
  5. Ernie12
    Ernie12 Active Member
    Ohio
    02 BD Pro Sport
    Ernie
    In my area Aug. 17,18 & 19 Huge parking lot sale the lift is $284.99 I wonder if you can use the 20% off coupon with the sale, now that would be a deal.
    PacoPetty likes this.
  6. roadie1389
    Wylie, Texas
  7. Blac94cobra
    Blac94cobra Member
    Tucson,az
    2004 big dog chopper
    Bob
    My brother has one and it works great. would definitely recommend it
  8. Ernie12
    Ohio
    02 BD Pro Sport
    Ernie
    Starts tomorrow !!
    pknowles, PacoPetty and Reddickracing like this.
  9. Th3InfamousI
    Texas
    The 20% off coupon excludes these parking lot sales which is what this weekends sale is. So anything in that email is exempt. Still this is a few bucks cheaper than the $299 Coupon, and this is the price I saw for their last parking lot sale.
    It's a great lift at this price point.
  10. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Harbor Freight is the Devil! Lmao
    BWG56 likes this.
  11. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    mama said mama said mama said HF is da debil
    BWG56, pknowles and PacoPetty like this.
  12. geoffmt
    geoffmt Member
    Billings, mt
    07 bull dog efi
    Geoff
    I have had mine for 4 years, the bulldog fits good, no complaints, especially for the $299 I paid
    PacoPetty and pknowles like this.
  13. Tim M.
    Tim M. Member
    Jax, FL
    2003 Big Dog Chopper
    Tim
    The trick to HFT lifts and Jack's is swapping the ram fluid out. The factory stuff is garbage. Same with the compressors, good product, garbage fluid. Swapped out my motorcycle fork lift's jack fluid for Sta-Lube Hydraulic and Jack Lift fluid by CRC, and have had zero issues even after months under load, buddy ran same bottle jack on his cherry picker, popped the seals and fluid bled out because the seals went, barely used the thing. Looks like same/similar jack/ram for the lift. Just drain the factory fluid and refill with a quality one, might not make it perfect or 100% bullet proof but certainly worth the $5-10 for the peace of mind and longevity. Same with the little $148 29 gallon compressor. Run it until it's nice and warm, drain every possible drop of the Chinese goat piss they use for lube out of it, throw in some Magnum synthetic compressor oil and it'll run like a champ and smooth. The regulator switch is super easy to adjust on it as well. Just my 2 cents.
    Sent from my SM-G930P using Tapatalk
    PacoPetty, SKOGDOG and pknowles like this.
  14. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Thanks for the tip! I just got the air compressor but I have not hooked it up yet.
    Tim M. likes this.
  15. 41bigdawg
    Portland, Tennessee
    Robert
    I have had that compressor for about 8 years now, put good oil in it when I got it and I've never had one problem with it.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  16. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I got it for Christmas and I still have not set it up! Lol
  17. 41bigdawg
    Portland, Tennessee
    Robert
    Wow brother...what are you waiting for? Christmas lol :)
  18. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Yes, I’ve never had one so I’m waiting for Santa to show up and set it up for me !
    41bigdawg likes this.
  19. Tim M.
    Tim M. Member
    Jax, FL
    Tim
    The little compressors are pretty reliable when maintained properly. You'll still have to do a couple "heat and drain" runs to help it break in properly (there are directions floating around on the cycle times / hours and oil changes for break-in) but once it's in a happy place, like I said before, fresh, quality synthetic compressor lube will carry it well. I sold my little guy (HFT) and kept my DeVilbiss 60 Gal, use the same lube (Magnum) and it runs like a champ. I ran it hard using an air hammer to bust up tile a couple weeks ago, even under hard duty cycles the cylinders held consistent temps (check via laser gun) in a hot FL garage. So, my opinion only, well worth the couple bucks. If the little guy keeps cycling too much, once the warranty is expired, it is easy to reset the regulator min and max pressure cycles. Its under a small cover on the side, two (?) Screws, with nothing but a bead of cheap hot glue keeping them set. Tank is rated to hold a bit higher loads consistently. I reset mine to hold pressure longer and minimize duty cycles, increased the high end pressure settings and lowered the bottom settings. Have fun! I'm trying to get my hands on a lift ASAP. Devil is in the details!
  20. Sven
    Sven Well-Known Member
    building one
    The lift I have was made over 40 years ago. It was leaking out the pump assembly. I took it apart and could easily find large and small orings for it. However, the main seal that was leaking was a one-off. I called a seal maker and they said 300 bucks to run the casting and whatever it took to duplicate it; that was the base price he quoted.
    I scratched my nuts for an idea; since my head is empty why go there. Anyway, I looked at the failed part and came up with an idea. I believe this might have the same cylinder pump design you might have there too? There are rubber head covers for some modern bike engines. They might be padding emission noises so this muffs the sound I'm guessing? This is the thickness you might want to use. I took a piece and traced out a 4-leaf clover design and cut it out for a gasket. I forget how many I cut out this way, but I then staggered them as they began to stack up in their holding place. The X and Y were in place, meaning, wide enough and tall enough in the matching up. I reassembled the pump unit, installed it, filled it up with ATF. I began pumping and it started leaking. Oh shit, I topped it off high as if it still had the same leak. That was the breather overflow and it was leveling it off. Those days are over when I had to pack a stack of flat paper towels sitting under that pump. Since it leveled off, maybe going on 3 years now heading for 4 and still a dry drip pan.
    Theory goes something like this: Lay your palm over the top of the other hand. The fingers are going in one direction. That's the layers. Pump your foot like you're raising the lift and then move your fingers as you pump. The clover leaf lets the oil flow over the bends. The gaskets return erect and each stagger is closing off the oil flow on the return... pull your fingers back up. She boom she boom, yada me ya she boom.
