Harbor Freight Lift
Discussion in 'General' started by awg, Jan 2, 2019.
  1. awg
    awg Well-Known Member
    Full Member
    Ohio
    2008 Big Dog Chopper, 1980 Honda Passport, 1965 Honda Benly, 1967 Sears Sabre
    So Eric ....you want to drive up and help me unload it?
  2. roadie1389
    roadie1389 Active Member
    Full Member
    Wylie, Texas
    Couple 2x6 ramps, put some pieces of PVC under it and use as a roller.
  3. awg
    Full Member
    Ohio
    VERY good idea.
  4. roadie1389
    Full Member
    Wylie, Texas
    Big D Florida and pknowles like this.
  5. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    That's still a good price on that lift
  6. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    And there you go.…..
    Big D Florida and speedball jr. like this.
  7. drK-9
    drK-9 Member
    Wichita, KS
    16 Streetglide, 07 Softail Custom, 08 BigDog K-9, 07 BigDog Bulldog, LE
    Craig
    Ok set it up with other chock and bulldog still bottoms out on the lift before I can pull it up even with air ride pumped up completely... maybe use a couple 2x4's and try again tomorrow?..
  8. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    I have to place a piece of three quarter inch plywood under the steel ramp to get my prosport on without bottoming out. Make it as wide as the ramp and about two feet long. The bike will ride up on the plywood then onto the ramp. Easy fix.
    Get some good motorcycle tie down straps to secure you're pike to the lift.
    Also replace the skinny little bar they use as a safety bar with a larger one. My holes are big enough to accept a one inch diameter bar. Also this should go with out saying don't try to move the lift with the bike on and raised up. Ain't nothing good going to happen.
  9. pknowles
    virginia
    paul
    I ran a ross a metal ramp(free) and it works great. Need to put some non-skid tape on it though.
    Reddickracing likes this.
  10. pknowles
    virginia
    paul
    I fabricated an aluminum box and moved the clamp forward about a foot.
    Clubba, chubs and Reddickracing like this.
  11. Minuteman
    Minuteman Member
    Full Member Supporting Member
    Orange, Mass
    06 K9, 02 Ultra, 77 FLH, 57 Sportster
    Ted
    When I unloaded my lift, I also bought 1 of there 4 wheel dollies for $15.00 and then just slid the crate off on to the dollie and rolled it right into the garage.
    pknowles likes this.
  12. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Ah, now I know where Eric get his brilliance from.
  13. awg
    Full Member
    Ohio
    Pretty much what I did to. I used a furniture mover. Like a flat 4 wheel cart. Had help pulling it out of the truck though. Rolled it into the garage. I put it together Sunday. I am going to buy the other chock HF has and others have used. My only complaint is I checked the hydraulic oil like they suggested. The plug they have was a pair in the ass to pull out and even worse to put back in. Has anyone else had a problem with this rubber plug? Also it was not full of oil. So now I have to buy hydraulic oil. I have my first bike on already to work on.
    njbiker20088 and chubs like this.
  14. pknowles
    virginia
    paul
    Don't overfill the hydraulic reservoir.
  15. awg
    Full Member
    Ohio
    When I look into the little hole I see nothing. The directions make it sound like you should see the oil up to the top.
  16. pknowles
    virginia
    paul
    Then it was probably shipped without oil. What does the instructions call for as far as a quantity?
  17. chubs
    chubs Guru
    Full Member
    indiana
    2002 pitbull Prostreet --
    runky
    Ya better get some tie-downs on that thing. If it was to fall over, somebody could get a nasty bruise !!
  18. awg
    Full Member
    Ohio
    It says, and I quote "The oil level should be even with the bottom of the filler plug hole. You should be able to see the oil. If the oil level is low, add SAE Hydraulic Jack fluid only. Avoid mixing different brands of oils." I have heard that sometimes these are shipped empty or not enough oil in them.
  19. awg
    Full Member
    Ohio
    Tie downs are coming!:)
    chubs likes this.
  20. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    Am there you go.....
