Having an issue with wheel hop
Discussion in 'General' started by oss, Sep 24, 2017.
  1. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    i'm having an issue between 70 and 80 mph. My new front tire will start to bounce at just over 70 mph and just at 80 mph it stops. Then it's smooth as ice. is there a such thing as too much with the beads?
  2. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Flat spot or shifted belt possibly
  3. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    I've got about 300 miles on it, but I think it's probably done it since it was new. I guess I've got to order another tire.
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    You triple check your tire pressure? Mine will do that if it's not damn near 42lbs under 40 it gets a little hop
  5. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    Will do
  6. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Do you use dyna beads?
    BWG56 likes this.
  7. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    :disappointed: Reread op and put your hearing aid in:oldhardlaugh:
    bdm7250 likes this.
  8. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    Thanks !!! That was the issue, next time I'm checking, " their work" or doing it my self.
    kickstart likes this.
  9. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    Yes, that's why I was asking if you could put too much in the tire. I was thinking it was the tire.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Put yo grasses on
    bdm7250 likes this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    How much did you put in?
  12. bdm7250
    bdm7250 Guru
    Doug
    Sorry, had the volume turned down..:oldhardlaugh:
  13. bdm7250
    bdm7250 Guru
    Doug
    Sorry, I stepped on them grabbing my hearing aid..:oldhardlaugh:
  14. Th3InfamousI
    Texas
    What was the PSI?
  15. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    It was at 30 psi . I'm not taking anything to that shop again. I had them change the front wheel bearings and the tire, while they had it. My bad for not checking the pressure when they gave me the wheel and tire to put on the bike.
    drK-9 likes this.
  16. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    I've had my front tire as low as 25psi only to feel is was tough to turn never got a hop or wobble
    HMAN and cdogg556 like this.
  17. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    This is my first cruiser, all my previous bikes were crotch rockets, so a low tire just made it sluggish in the turns (very noticeable with just a few psi).
  18. Th3InfamousI
    Texas
    You gotta go faster than 70 ..lol..
    It's just a little hop and you can't really feel it but if your looking at the tire you can see it. Might not actually happen on your old pitbull actually just because there is more weight on the front end. I bet it doesn't on the prostreets just because of that. Longer bikes just don't have much weight on the front tire.
    Give it a try on your k9..and it's usually about 68mph - 77mph it just has a little bounce it's not smooth. Again you gotta be looking at it you won't really feel it
    dentdude36 likes this.
  19. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    68-77! Not sure I can do that:oldhardlaugh:
    BWG56 likes this.
  20. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Was talking to a guy this morning before I left Dave's that was having the same problem. They broke the tire down and took the beads out, the spun balanced it. They did it 3 times and with out any beads in it, it was perfectly balanced. Put it back on the bike, and wheel hop was gone. Could be something to that.
    TapioK and Nukeranger like this.
