Headlight/High Beam
Discussion in 'Technical' started by roadhogg, Jul 27, 2017.
  1. roadhogg
    roadhogg Member
    K9
    Hey just looking for some ideas for a problem or if anyone has experienced it before,the headlight on my 09 K9,the high beam light when you flip the switch on for it,it lights for a few seconds then goes out after flipping from low beam,any ideas,thanks
  2. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    The indicator or the actual light
    PROFLYER likes this.
  3. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    the indicator light or the high beam itself goes out after a few seconds? What type of bulb are you running?
  4. roadhogg
    roadhogg Member
    K9
    the light
  5. roadhogg
    roadhogg Member
    K9
    stock bulb
  6. roadhogg
    roadhogg Member
    K9
    stock bulb
  7. bigkelk9
    07 big dog k9
    Kel
    Willing to bet ur light is going out.. if ur controls are operating as they should.. that's what's going on no doubt. Just happened to a buddy a few months back. I was with him when it happened
  8. bigkelk9
    07 big dog k9
    Kel
  9. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    Sutton
    bigkelk9 likes this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Replace the bulb as others stated
  11. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Also when you replace the bulb, crimp the connectors in the plug, so it fits tight. A loose connection will create heat and burn the plug.
  12. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    High beam bad. Goes to low automatically.
    BWG56 likes this.
  13. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Replace it with a daymaker..:old2: I'm a believer..
    bigkelk9 and BWG56 like this.
  14. roadhogg
    roadhogg Member
    K9
    thanks all I resolved it
  15. bigkelk9
    07 big dog k9
    Kel
    And replaced it with a daymaker???
  16. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Maybe you could explain how. It may help someone else out who is experiencing similar issues.
  17. bdm7250
    bdm7250 Guru
    Doug
  18. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    I was having a problem where I’d start the bike and the low beam would come and stay in. I’d hit the switch and nothing would happen. The indicator would slowly blink. I was told possible ehc issue. So I sent it off to be tested. I’m hoping that is what was causing it.
  19. SimpleMan_Omen
    SimpleMan_Omen Active Member
    Georgia
    2003 Big Dog Pitbull, 2004 V-Strom 1000
    Aaron
    I just bought a 2003 Pitbull that the high beam wouldn't turn on. I narrowed it down to being the EHC (Thunder Heart). I spliced the wire before the EHC into the wire after and it now works. The blue high beam dash light even comes on after doing so.
