Help! My new dog died!
Discussion in 'General' started by drK-9, Nov 17, 2017.
  1. drK-9
    drK-9 Member
    Wichita, KS
    16 Streetglide, 07 Softail Custom, 08 BigDog K-9
    Craig
    So we got a little bonus weather day here in Wichita, so I took off work a little early and took the new (to me) 08 K-9 efi out for THE MAIDEN VOYAGE. Everything was perfect, felt like I was on cloud 9, running great, very strong. So about 15 miles into the ride I pulled up to a riding buddy of mine's house to show off a little, he didn't know I got it. We looked it over for a few and off I went, only this time when I started it, it started cutting out, burping and farting, and died after two blocks. Couldn't start it and keep it running for crap, it will make the fuel pump prime up sound, fire up and die, like it is starving for fuel. Well, I pushed it back to my buddies house sad and dejected, pushed it into his garage, and he just brought me home. It's sitting there in his garage won't run for shit. Any ideas??? Thx
    We both have stuff to do tonight, so I guess I'll go over tomorrow with my trailer and pick it up.
    chubs likes this.
  2. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Bad fuel? Plugged fuel filter? Guessing game with little information.
    chubs, Unsprung, Forsaken and 2 others like this.
  3. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Test battery , Check vfi for codes also sounds like it could be engine temp sensor
    Unsprung and BWG56 like this.
  4. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    gas cap vent clogged. try unscrewing the cap and listen for a hissing sound.
  5. Forsaken
    Forsaken Active Member
    Southwest Florida
    2005 Big Dog Chopper
    Gil
    Bummer for your first run....like Doug said, fuel problem??? I think there's a troubleshooting checklist on the forum....get it and let us know what you find.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree: with #2, #3 and #4
    bdm7250, Unsprung and dentdude36 like this.
  7. drK-9
    drK-9 Member
    Wichita, KS
    Craig
    I just talked to one of my mechanic buddies he thinks I may just have fouled a plug.... sure hope that's it.
    chubs likes this.
  8. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    right behind a bad vent, that would be what i would want to hear about. cheap fix! good luck.
    chubs likes this.
  9. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    Not to insult your intelligence in any way shape or form, but how much fuel is in it? If low it may need switched to reserve and fueled up.
    chubs likes this.
  10. Brandon Downey
    Anderson, IN
    Brandon
    Ahhh ok good to know. Thanks. I think I need an efi bike to park next to my carb bike
    Unsprung and chubs like this.
  11. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    The thought of efi is nice but it seems that s&s carb is much more reliable the s&s efi not just in big dogs but ironhorse and other custom applications
    kickstart and bigkelk9 like this.
  12. drK-9
    drK-9 Member
    Wichita, KS
    Craig
    I'm going to try replacing the spark plugs first this morning. What kind of operation is it to pull the tank, and change the fuel filter? Thx
    chubs likes this.
  13. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    I think u might have an issue with the fuel pump itself. There is a bike here locally that had the same issue and it turned out to be a fuel pump, another member here who don't visit n e more had a 2010 bulldog bagger, had the same issue.. Idk specs for pressure, but if u can find em I would test pressure first. Just guessing from what I've read and what seems to be a common EFI issue.. good luck brother
  14. Unsprung
    Ruskin, FL
    Gerald
  15. drK-9
    drK-9 Member
    Wichita, KS
    Craig
    Well, just replaced the spark plugs, yes they needed it, but no dice. Damn thing still won't run. I can hear the fuel pump prime up, it fires up, and poops out. Trailered it home. Looks like the tanks coming off...
    chubs likes this.
  16. bdm7250
    bdm7250 Guru
    Doug
    Did you try running it with the gas cap off?
    chubs likes this.
  17. drK-9
    drK-9 Member
    Wichita, KS
    Craig
    Yes I took gas cap off and tried that.... no go
  18. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    did you check to see how much power you have coming out of the coil to the plugs? may just not be hot enough.
    chubs likes this.
  19. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Could be clogged fuel tank or lines.
    chubs likes this.
  20. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    X2
    Worth checking out. Put a fuel injection gauge on and see if it holds pressure on the rail
    chubs likes this.
