Help Please! Bike shutting down!
Discussion in 'Help Wanted' started by KROGOTH, Aug 25, 2011.
  1. KROGOTH
    KROGOTH Active Member
    Its a 2009 Mastiff. No the lights stay on when it goes off. I tried yesterday again, started perfectly and stayed on idle for a minute. Then I went for a ride. 1 minute into it as I came to a stop I felt it sputtering. Kept the enging revving high and made it back. As soon as I let go of the throttle it stopped. I tried to start and nothing. I let it cooldown for at least 30 minutes and still nothing. :bang:
    By the way, do I spray once the engine starts up?
  2. KROGOTH
    Went to start the bike this morning and it started like a charm. Most likely the intake seals are the culprit as suggested. I will buy some brake cleaner and see what happens and also try to convince the mechanic here too.
    By the way where do I buy the intake seals for my 2009 Mastiff?
  3. bdhusky00
    bdhusky00 New Member
    central arkansas
    2000 Bigdog Husky, 1999 Harley sportster sport.
    mike
    i had a simular prob on my 2000 husky, thought it was a fuel problem. found it to be my ignition switch. its a quick one to diagnose just by tying your wires together and goin for a ride. but my symptoms were not exactly the same. probably not the problem, but its worth tryin. goodluck
  4. bigdogtech01
    bigdogtech01 Well-Known Member
    Endwell, NY
    '06 Roadstar Warrior, '04 KTM 450 Super Moto
    Andrew
    Your '09 will have the new 50 degree ignition switch in it so I'm sure that's not the problem. Lik e I have already said, it's probably te intake seals. You can get them from anyone that get S&S parts. Make sure the seals are S&S. H-D will not work. They are a thicker rubber and will not seal. If no dealers in your area ten you might have to order off the net or from someone on here maybe.
    PZNIVYCHOPPER likes this.
  5. PZNIVYCHOPPER
    PZNIVYCHOPPER Active Member
    LONG ISLAND,NY
    Bdm Chopper/ bbb custom chopper/ c50 touring/ Independence chopper
    Bigdogtech01 ,Andrew has helped me more times than i would like to admit. He knows!
  6. KROGOTH
    Thanks all and Andrew! We will work on this tomorrow and will let you know how we make out. My money is on what you said as it makes sense. Anyone here sell these seals? Let me know and I will be a buyer
  7. erldawg
    erldawg Guru
    Raleigh, NC
    2008 K-9 EFI
    Earl
    You could use carb cleaner as well to search for intake leaks...
  8. bdmridgeback
    bdmridgeback Low Down Chop Shop
    SW FL
    '05 Ridgeback
    Jake
    Watch adding any additives to the gas. The internal tank liner does not like some additives
    and will begin to flake or peel with some. That can plug up the pick up screen and carb.
  9. KROGOTH
    Ok. Today we sprayed the intake seals, and dog stayed on. Then as it warmed up more it sputtered off. Started again and would not go on. We took the gas line off the carb and we saw a thin black spiral peace coming out. We worked it out and flushed the line.
    Started up like a charm. Wednesday we will take the carb apart and clean out any debris.
    My question is, why did this only shutdown when it got hot? What is the techinical reason beind that? Thankgod it was not the intake seals.
    BDMRIDGEBACK, thanks for the advise. I only poured a few drops of the octane booster. But will not use it again for sure.
    Thanks all for the help and the advice. Its hard to find good people on this little island
    with your expertise.! I will let you know what or if we find anything? Thanks!
    Rottweiler likes this.
  10. silver09
    silver09 Active Member
    Smackover, AR
    09 k9, custom rigid chopper, 09 hayabusa
    Tad
    Well that 's good to hear might you have found the problem. It's always something simple.that problem to me just didnt sound like electrical .
  11. Ohmster
    Ohmster Kansas Motorcycle Works
    Wichita, KS
    Jason
    Absolutely Ray. We have a small little bar just a few blocks from the house that has some of the coldest beer I've ever had. Dollar draw nights make for some good times and its easy on the wallet.
    On a side note I picked up the engine and tranny for the bike I'm building for a guy. Bought it off an aircraft worker that's been on layoff for awhile so he was looking for some quick cash. Got a S&S 107 with black wrinkle finish with diamond cut cylinders and a Baker tranny with it for $3k. Pretty much stole it, guess that's one bright side to the economy.
  12. KROGOTH
    Ok it started all over again. Especially if I ride the bike hard that is 5 to 10 minutes
    at high throttle. It would start to pop on the down shift and then eventually shutdown and not restart
    We took the carb apart and it was clean. We checked plug sparks, no problems.
    Tried to start and when we took plugs out again they were dry. My mechanic said they should be wet. We started tracing fuel lines and eventually noticed the equalizing line dry. We disconnected the bottom of the carb and nothing came out. We tapped the housing and then fuel came out. The float was stuck. Then it overflowed, so it got stuck
    in the fill position. We determined that when the carb heated up the float was sticking and thus starving the engine with no fuel. That was why when it was cold it worked ok. Anyone ever have this issue???? I am using a Big AIR PSI. What is the fix? Thanks!
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I'm guessing he did:old2:
    KROGOTH was last seen:
    Jul 14, 2012
    cdogg556 and dentdude36 like this.
  14. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    :oldeek: :disappointed:
    dentdude36 likes this.
  15. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I didn't read through it to see if he got his problem figured out, but most guys get what they need and are gone, he'll be back when he needs us again. ;)
    Rottweiler and dentdude36 like this.
  16. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    I feel so dirty and used lol.
    cdogg556, BWG56 and dentdude36 like this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Get used to it Putz:oldhardlaugh:
    cdogg556, bdm7250 and dentdude36 like this.
  18. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :stupid::agree: IMG_9380.JPG
    cdogg556 and BWG56 like this.
