Help
Discussion in 'Help Wanted' started by Gmutoagrsv, Nov 14, 2017.
  1. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    i have had the bike up on the stand for a lil over a month. I put new leds Dakota digital speedo and pipes while it’s been sitting. I finished it all last night. Started it up and noticed it instantly when I turned the key on I was gonna have a new problem. The headlight didn’t turn on. I have all other lights and it runs fine. But no power at the plug. I didn’t touch the headlight other than loosening it to run my lights. I’ve searched a ton of phrases and can’t think of any other way to search. I do think I remember seeing something someone wrote with similar issues with unplugging the battery or it dying. The gauge lights up and the high beam light dimly flashes. What do I look at next?
    chubs likes this.
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    in that month, did you have the battery on a tender?
    chubs likes this.
  3. chubs
    chubs Guru
    indiana
    2002 pitbull Prostreet --
    runky
    Starts and runs fine, no headlight. Good ground ? possible short, or bad connection ?
  4. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    i Didn’t put the tender on it till after a couple weeks after. But it’s been on it sunce
  5. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Started and runs just fine. Breaklights signals all work. Tried to go as simple as a test light to the harness and nothing is hot.
    chubs likes this.
  6. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    could be that little JST connector in the light harness located under the gas tank.
    chubs likes this.
  7. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Jst?
    chubs likes this.
  8. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    It’s a daymaker
    chubs likes this.
  9. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Ya. I figured that. That’s why I grabbed my test light. And none of the leads were hot
    chubs likes this.
  10. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I'd take the daymaker out and check your ground. Sometimes people grounded them to the bucket or cut and splice happened and it now is coming apart?
    Obviously gotta find out where your short is if you don't have +12v to the headlight.
    chubs likes this.
  11. chubs
    chubs Guru
    indiana
    runky
    When I put my Daymaker in, it turned on very dimly , but when switched to hi it lit up and kept working correctly after that. Had me baffled.
    pknowles likes this.
  12. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Maybe try your old bulb.
    BWG56 likes this.
  13. bdm7250
    bdm7250 Guru
    Doug
    Prolly got 20 "in stock" as well..:rolleyes:
    francoblay1, dentdude36 and BWG56 like this.
  14. bdm7250
    bdm7250 Guru
    Doug
    Ya, I suggested he try his old bulb.
    chubs likes this.
  15. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Gonna try it tomorrow. I just don’t understand why I wouldn’t have anything on my test light.
    chubs likes this.
  16. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    They’re wired to the battery directly. I was able to finish the leds and speedo and the headlight was working. Then it sat for a week or so without the tender in it. And after that it was sitting a couple weeks.
    chubs likes this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's good that the LED's are wired direct to the battery, maybe you want to have the battery load tested if ya already tried the old headlight bulb.
  18. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Yeah, as dent said, I'm on my third daymaker.. some have lots of luck and others dont. But i wouldnt trust a test light, i would use a meter and wre what u got and if nothing still, might have yanked a wire from under the tank on one of them flemsy ass jst connectors.. if u got no power at the harness to the bulb, ur gonna have to yank the tank and go there next.. it' next in line.
    #18 bigkelk9, Nov 15, 2017
    chubs likes this.
  19. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    I pulled the led and put the stock headlight back in and nothing. I checked and also noticed the alarm won’t arm or disarm. It chirps when I pull it from the battery. I took it out completely and still nothing. I ordered a few thing I needed like the rubber height adjust for the tank. So it came in and I’m waiting till I get a few min to pull the tank and check the wiring. And am lost if that doesn’t do anything. The only electrical thing I’ve done since I parked it was the speedo. But I don’t know
    chubs likes this.
  20. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    So I pulled the tank up didn’t find anything that looked messed up I followed the wires from the headlight and found they go into the coil pack and I tested them there with the test light and all three Lugs showed light ground with the key on and off and there’s a ground bus below it as well. Anybody want to do an experiment on theirs and see if it comes up grounded as well?[​IMG][​IMG]
    chubs likes this.
