How many miles on your Dog?
Discussion in 'General' started by BWG56, May 4, 2017.
  1. 0-5K
  2. 5-10K
  3. 10-15K
  4. 15-20K
  5. 20-25K
  6. 25-30K
  7. 30-50K
  8. 50K+
Results are only viewable after voting.
  1. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    To break the mainshaft you really had to be thumping on it. Along with some excessive heat.
    Big D Florida and dentdude36 like this.
  2. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    So why was the shaft updated? I hear different reasons
  3. Th3InfamousI
    Texas
    It was just a weak point..ive only seen them break where the threads end not anywhere else like you had mentioned.
    And I can only recall a maybe 5-10 that actually broke on this forum. I'm sure there's more but those numbers are low. Now bearings and crap and play in the mainshaft that has been way too many to count. Some people have had luck Raywood had 90k no rebuild, Blacktopper had 60k without issues. I think part of the issue to is that clutch hub nut coming loose if that walks out so doesnt the mainshaft. Beats the hell out of the bearings as the whole clutch assembly just wobbles around.
    PacoPetty, TapioK and dentdude36 like this.
  4. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    That makes sense
  5. Forsaken
    Forsaken Active Member
    Southwest Florida
    2005 Big Dog Chopper
    Gil
    Just maybe...on occasion.
  6. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    My trans has been quite smooth for as long as I've had my mastiff (2011), I guess it musta been built on a Wednesday, not a drunk Friday or hungover Monday..:oldlaugh: no major issues with it so far, biggest expense was ESC , and I only put that in because I couldn't stand having the rats nest of wires with the PDM..
  7. BWG56
    BWG56 Guru
    Chocolatetown, PA.
    07' Mastiff, DOC's ESC, 585DualRunner, Spyder F3T
    Ker
    They had the updated shaft in them by 08' Putz:oldsmile:
    bdm7250 and dentdude36 like this.
  8. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    :cry:
    bdm7250 and BWG56 like this.
  9. bdm7250
    bdm7250 Guru
    Doug
    I was more referring to the fact that mine don't spend the majority of its life on a lift :crazybitch:..no offence Eric. :oldhardlaugh:
    BWG56 likes this.
  10. bdm7250
    bdm7250 Guru
    Doug
    :stupid: Big :cry:.
    dentdude36 likes this.
  11. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    :disappointed:
    bdm7250 likes this.
  12. bdm7250
    bdm7250 Guru
    Doug
    WTF you disappointed about...the emoji says that I'm with stupid....:oldhardlaugh:
  13. PacoPetty
    PacoPetty Active Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I need to service mine and I bet my clutch hub nut is loose.
  14. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    What makes you think that? If you need to adjust your clutch cable often then it's possible , you can also pull inspection cover and make sure the chain and gear doesn't move around excessively
    bdm7250 likes this.
  15. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I don't know what to call it other than I have some play in my shifter and my clutch will kill your hand at long red lights bc the bike rarely goes into neutral if it's running.
    chubs likes this.
  16. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
    Try adjusting cable first should be a dime space between lever and hand control if that doesn't work adjust the clutch rod I've never done it maybe someone will chime in and explain how it isn't very hard
    chubs, bdm7250 and PacoPetty like this.
  17. BWG56
    BWG56 Guru
    Chocolatetown, PA.
    Ker
  18. dentdude36
    dentdude36 Guru
    WNY
    2007 K9
  19. Th3InfamousI
    Texas
    You still have stock big dog levers?
    I only ask because when Kel was here he was adjusting his clutch and it was flopping around like a dead fish, I kept telling him he needed to keep tightening it and low and behold it was slack in the lever. Was too tight and harder than hell to pull too. But you couldn't tighten it enough for to the worn bushing. It's his Harley controls the bushing was worn and also the leverage was less than what was on stock big dogs.
    On my bike after I do half pull it just falls into place not hard to hold it at a light can do it with two fingers.
    chubs and bdm7250 like this.
  20. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I have stock levers.
    chubs likes this.
