REMorris
OK Rider Shakey
I don't know yet. they have had my bike since last Saturday (slipping clutch). When I pick it up, I will get them to copy the procedure and I will post it.whats the differance????
You can order an "easy pull kit" from BDM. That will help ya.Hi all, I just got the k9 out of customs, finally after about 2 months /sigh
Everything is "fine" (they did damage the tank and rear fender but thats another story)
I've always had harley's and Japanese bikes, I was driving the dog on friday thru a highway jam and I noticed the Clutch handle was very hard to keep disengage (the clutch appears to be working fine, it engages and disengages fine and gears all change easily) but as I spent 30min to 1 hour in that traffic jam constantly pressing de-pressing the handle I realized how much harder it was from my previous harley.
Also, changing gears is a brezze but finding neutral is extremely hard.
My question is, would this adjustment help at all with the handle bar pressure and finding neutral?
Nope no evident wear on the basket, was going to check the cable when I get home , yeah was just kinda of odd with the way it was acting. Was trying to see if anyone else had this same type issue and what was the cause. Guess there is that possibility of worn disk I do do ride my dog hard maybe it just wore a little soonerTLB,
It's had to say from here with the info given, but like you say"maybe" worn disc, but I doubt it on an '08 unless it's adjusted to tight & slipping. Have you checked for a "possible" fraying clutch cable that's stretching out? What's the clutch basket look like? Basket not bent or broke?
so i did the adjustment, and now shifting is smoother than before, finding neutral is still a pain while the bike is running, the moment i turn it off i get it right in what could be causing that? or should i adjust it differently ?
