How to: CR replacement
Discussion in 'How-To' started by bdm7250, Jan 28, 2018.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Replacing the compression releases with rocker boxes removed.
    Remove the six cap screws from the rocker box cover, and remove the cover.
    Remove the two 5/16" bolts, two 5/16" cap screws and two 1/4" cap screws from the rocker arm stanchion and remove the assembly.
    Remove the six 5/16" cap screws from the rocker box, and remove the rocker box.
    Clear away any gasket material.
    Using the S&S CR removal tool, remove old CR.
    #1 bdm7250, Jan 28, 2018
  2. bdm7250
    bdm7250 Guru
    Doug
    These are the original compression releases and were a little tired.
    Apply anti-seize to the threads and install new CR, make sure the washer is seated properly and torque to 37 foot pounds.
    With the rocker boxes removed, it is much easier to install the rubber boot and route the wiring correctly. The kit has plenty of heat shield for the wires, I spliced mine at the same spot as original.
    Once wired, I pulled the green wire from the starter and tested, as long as the start button was held down, the CR stayed down.
  3. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Thanks for the how-to Doug.
    Another great post to add to my notes so it won't get lost.
    :old2:
    Big D Florida and dentdude36 like this.
  4. bdm7250
    bdm7250 Guru
    Doug
    Clean off all the loctite from the bolts and cap screws, (this will eliminate false torque readings), run them down in the heads, should go in easily by hand.
    Make sure the gasket surfaces are clean.
    Install the new rocker box and gasket, finger tight with the six cap screws. Make sure to use blue threadlocker.
    Install the rocker stanchion with the 5/16 bolts and cap screws, also install the two 1/4" cap screws.
    Torque the four 5/16" cap screws/bolts to 18 foot pounds, crisscross pattern as shown in the manual.
    Torque the six rocker box cap screws to 18 foot pounds, and the two 1/4" cap screws to 8 foot pounds (100-120 inch pounds)
    Install rocker box cover gasket in the groove, put the clean cover back on and torque the six cap screws to 8 foot pounds, be sure to use blue threadlocker. IMG_9675.PNG
  5. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Nice write up.
    Thanks for posting
    bdm7250 and dentdude36 like this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good job:old2: Looks familiar:oldsmile:
    bdm7250 likes this.
  7. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    That was awesome
    bdm7250 likes this.
  8. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Was wondering about where you got 37lbs, since BigDog list 35 in the manual. Y'all are welcome for that S&S 117 manual..lol
    Just for the record to keep it all in this post S&S manual states 32-37lb torque with antiseize. Big Dog just states 35lb with antiseize. I would stick with what Dougie posted to try and prevent them from flying out down the road, they are under a lot of pressure.
    Nice work Doug
  9. bdm7250
    bdm7250 Guru
    Doug
    When dealing with small torque values I have a tendency to stick to the higher end of the range. Just habit..
    pknowles likes this.
  10. bdm7250
    bdm7250 Guru
    Doug
    It would have been quite aggravating with the rocker boxes on.
    BWG56 likes this.
  11. Th3InfamousI
    Texas
    I agree especially with anti seize 37 is what I'll use too when it comes time.
    bdm7250 likes this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Sometimes experience is worth a thousand pics:old2: great write up
    bdm7250 likes this.
  13. Mike manson
    Mike manson Well-Known Member
    Erie pa
    2005 bigdog ridgeback
    Mike
    Nice I have to change my tp rockers for s&s I bought
  14. wewjr71
    wewjr71 Two Bad Bitche's In My Sleeping Bag
    Bristow,VA.
    06 Pittbull, 16 Breakout,16 sportster 48
    william
    thank you
  15. Twisted
    Twisted Well-Known Member
    Hazlet, New Jersey USA
    2005 Big Dog Chopper
    Butch
    Awesome write up Doug, nice work!
    bdm7250 likes this.
  16. Dakota
    Dakota Well-Known Member
    Western MA
    '06 Mastiff
    Dave
    Nice job Doug. :old2:
    bdm7250 likes this.
  17. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    This should prolly be a STICKY if there isn't one already:old2:
  19. bdm7250
    bdm7250 Guru
    Doug
    What do you mean, I washed my hands first..:eek: :oldlaugh:
  20. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    Great job and more knowledge, thx
