Interesting bearing failure artice on 6 speeds
Discussion in 'Dyno Runs' started by Nomad2day, Jun 29, 2008.
  1. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    I too don't use 6th unless I'm cruising on the highway 70 or better. Yes, an outer bearing support would be wise if your running an open primary...:D
  2. armad
    armad Active Member
    upper midwest
    08 Mutt, 06 Warrior, 99 Roadstar
    I do not like the Baker six. I have heard all the comments about how great the six speeds are for a bike. I just don't see why. Its the one thing I don't like on my bike. I rarely use sixth gear. Unless, I am cruising 80 or beyond. To me it seems to lug with anything less than 80, and there is much more vibration. I live where the speed limit is 55mph, and do not get on a freeway often. With a bike that makes the horsepower ours do, I would think a 5 speed would work just fine. My bike has 3000mi on it and I have owned it for a couple months. I am looking for other options, but baker doesn't offer other gear ratios from what I have been able to find out.
  3. DR BULLDOG
    DR BULLDOG DR BULLDOG
    Kingsland GA
    04 Bulldog
    Donny
    Great Article Do you Run Synthic Oil in the Traney ?????? Donny
  4. erldawg
    erldawg Guru
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Excellent article Neil. Like a few above I only use 6th when I'm above 75-80 mph and always downshift when accelerating.
    I use Spectro 6 Speed Synthetic 75w-140w. Recommended by Baker..
    #24 erldawg, Aug 10, 2010
  5. LukeDM
    LukeDM Active Member
    Oklahoma
    2005 Ridgeback
    Lukas
    Whaaat? I stack hay in D 3!! :loony:
    :lol::roll:
    Anybody with tractor experience should know to drop it down to accelerate! :up:
  6. outdoorsman26
    outdoorsman26 Well-Known Member
    madison, WI
    2007 mastiff
    matt
    my bearings just failed and I removed the trans wondering how to align it when I put it back in??? any help?? thanks
  7. Que
    Que Member
    Mandeville
    2007 Big Dog Chopper
    Same here, need instructions on alignment of transmission and belt. Removed my transmission to replace the bearings and now my belt wants to ride on the outer edge of both pulleys no matter how I adjust the rear wheel.
  8. outdoorsman26
    madison, WI
    2007 mastiff
    matt
    I didnt remove the motor so I bolted the inner primary to the motor then to the trans, tighten the motor up then the trans, then go underneath and tighten the trans
  9. troppushcet
    troppushcet Member
    07 K-9 Flat Black
    If you have not loosen your motor bolts at all?! After tightening the inner primary to your motor and transmission. Before tightening the 6 transmission mount bolts, you need to look that the gap the transmission may have bewteen the frame and transmission. It may need shimmed? From the sound of it and no matter what you do, belt keeps tracking to the outer edge after having the transmission removed and put back in, would mean when tightening your transmission down, your transmission is not align with your motor or rear wheel. Which also will cause other problems for you. Good luck!
  10. Thunder Dog
    Thunder Dog New Member
    Kentucky
    Big Dog Mastiff
    John
    I think your talking about this kinda failure..!!!!! this happened to me yesterday. The hex strikes again
  11. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Valid points on torque and accelerating in 6th gear but your facts and math are off in other regards.
    5th gear is 1to 1 ratio input of drive shaft to output shaft relative -- NOT related to rpm of engine
    -- Think about it for a second -- How could you sell a 5thspeed tranny rated as 1:1 if your description were true since you are not taking into consideration the pulley ratio from engine to clutch in the primary, also the ratio from the output pulley on tranny to final belt pulley.
    6th gear over drive input shaft if going .89 for every 1 turn of output shaft -- ie overdriving it. ie same speed on road, engine rpm goes DOWN in overdrive and therefore doesn't work as hard! (you have this described backwards.)
  12. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff
    Paul
    Not carved out of billet, or are our trannys made even cheaper for B.D.M. ?
    Paul.
  13. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    What y'all beating' up on Neil for. This thread was started back in June of 2008.
    BWG56 likes this.
  14. pauly
    pauly Active Member
    Paul
    That was a Baker statement I believe and not Neils words I commented on.
    Paul.
  15. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Just replaced the outboard bearings on my 03, has close to 90,000 miles on it. To my knowledge, nothing has ever been done to this Jims, except through out bearing.
  16. KnotSo
    Western Washington, the State
    Always an interesting read...
    :chopper::chopper:
  17. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Yes interesting read thanks for pointing it out.:old2:
  18. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    This thread just verifies what Andrew Barnes says... the BAKER open primary is the best thing for longevity and beatlring/shards life for the transmission and better yet a good reason not to increase horsepower.
  19. BigDogRick
    BigDogRick Active Member
    Phoenix, AZ
    2000 Big Dog Vintage Classic, 2008 HD Fatboy
    Rick
    05 is the year I upgraded my Vintage to a six speed. Fortunately, my then Big Dog mechanic was going to a show where the Baker boys were showing off the new six speed tranny and were strongly advocating the new gearing that delivered a 1:1 in sixth gear. I chose that option and am really glad I did. That was 40,000 miles ago and she still sings.
