Is my transmission drain plug being blocked by this plate on the bottom?
Discussion in 'Technical' started by No H2O, Jul 9, 2018.
  1. No H2O
    No H2O Active Member
    DC
    2004 Ridgeback, 2004 BMW R1150r, 2001 Fat Boy
    Mark
    In the video I looked at, the transmission drain plug was at the bottom.
    I went to do mine and saw this plate blocking ... everything.
    I'm hoping my transmission drain plug is somewhere else/accessible.
    2004 Ridgeback
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    that looks like somebody's add-on. is there a hole worn through the frame?????
  3. No H2O
    DC
    Mark
    Are you talking about the plate welded onto the bottom of the frame? If that's not stock I guess that means the drain bolt is inaccessible :-(
    Weird thing is when I pulled the fill plug the fluid was clear just like the PO said that it had been recently changed.
  4. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    just have never heard of or seen diamond plate used on a BDM.
  5. No H2O
    DC
    Mark
    The diamond pattern is an optical illusion since it's reflecting the pattern of the jigsaw mat on the floor that I'm using as a kickstand pad since I find it easier than those ubiquitous slotted kickstand gizmos
  6. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Your drain plug is not on the bottom. It's the plug on the side, in the center of the bottom.
    bdm7250 and francoblay1 like this.
  7. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Unsprung, Reddickracing and BWG56 like this.
  8. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :yesnod:
    :agree:
    BWG56 and francoblay1 like this.
  9. HMAN
    HMAN Just like to ride
    Ks
    Harry
    That 'flat plate' is the bottom of your oil tank. Ridge and Pit had "hidden" tanks.
    francoblay1 likes this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Hence the oil line going into it to the left of the arrow, "insert thumbs up emoji"
  11. No H2O
    DC
    Mark
  12. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    well, there you go. I figured somebody with some knowledge would come along sooner than later. looks like your plug is actually easier to get to than a lot of the others like the K9. that thing is a bear.
