Karata open primary install
Discussion in 'How-To' started by bdm7250, Jun 18, 2017.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Quick write up on installing the Karata 4" open primary. There are install instructions in my Dropbox https://www.dropbox.com/home/Big Dog but I took a few pics and will run through the install quick in case it may help someone else out. Had great advise/assistance from Dentdude, Ker and staffy, thanks a bunch for everything. :old2:
    Part 1: deconstruction
    Drain primary and remove outer
    Loosen the clutch cable on the downtube, remove the clutch rod cover, and remove the clutch rod. I removed my exhaust, takes very little time and gives you more room and less chance to damage anything.
    Take off the side covers and remove the two starter bolts.
    Pull the starter back away from inner primary
    Remove the diaphragm spring (4 bolts) and loosen primary chain tensioner.
    Remove motor and clutch hub nut, please remember the clutch hub nut is left hand thread.
    Slide everything off the tranny and motor shafts
    Remove the eight inner primary bolts and remove the inner primary
    Be sure to remove all gasket material from motor and trans, also now is a great time to clean the tough to reach spots. Remove any excess thread locker from motor and trans shafts, good cleaning of each.
    chubs likes this.
  2. bdm7250
    bdm7250 Guru
    Doug
    Part 2: Install
    Dry fit motor plate and pulleys, you may need to loosen trans mount bolts. You want to check alignment of the pulleys with a straight edge.
    Check your motor plate at trans and motor with a feeler gauge, everything must be aligned precisely. There is no need to put the belt on at this point, I just wanted to see how difficult it was, plus I was a tad excited to see what it looked like.
    Once satisfied everything I'd aligned, pull it all back off and start wet assembly. Blue loctite on the motor plate bolts and cap screws, and a healthy serving of red loctite on the trans and motor shafts, please note that both shafts get a spacer behind the motor plate, and the trans shaft spacer is directional (tapered end goes in). Torque both shaft nuts to spec (remember, motor shaft is right hand thread and trans is left handed) use the nuts that are supplied by Karata.
    Re-install your starter, I removed the o-ring as it's not needed.
    Remove the clutch rod shaft seat from your stock throwout bearing, and install in the Karata throwout with the stock snap ring. Install your clutch plates, friction plate first, once all plates are in align your pressure plate with grooves in pulley (so it correctly seats on last friction plate) I didn't do this first time so it caused me some needless aggravation.
    I am using the gold clutch springs, they provide plenty of pressure and clutch pull is very easy, use blue loctite when installing..
    Now install the belt, it is a tight fit but goes on by hand without needing to pry, the last half inch I used a soft head rubber mallet .
    Install outboard bearings, use blue loctite.
    And install outboard bearing support using blue loctite
    #2 bdm7250, Jun 18, 2017
  3. FrankBDPS
    FrankBDPS Well-Known Member
    Navarre,Ohio
    Frank
    Nice work. That outboard plate looks great.
    chubs and bdm7250 like this.
  4. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Very cool. Great reference :old2:
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Nice write up Doug:old2:
  6. Dakota
    Dakota Well-Known Member
    Western MA
    '06 Mastiff
    Dave
    :agree:
    chubs likes this.
  7. Big D Florida
    Troop Supporter Supporting Member
    X2 :old2:
    chubs likes this.
  8. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Sweet! I love the sound of those!
    chubs likes this.
