Lost
Discussion in 'Dyno Runs' started by wolfen, Apr 25, 2015.
  1. wolfen
    wolfen Member
    Mays Landing, NJ
    2005 chopper
    Sean
    Hi , Where can I get my Big Dog Chopper Dyno Tuned in New Jersey. Or at least in the south jersey area. Everywhere I look they don`t have a dyno big enough to fit my bike.
    Thanks
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Try Throttle City
    He's in Levittown, PA, not far across the Burlington Bristol Bridge. He is a very good mechanic and he's usually the one showing up to dyno tune at area shows (delmarva bike week and many others)
    Throttle City
    5426 Emilie Rd, Levittown, PA 19057
    (215) 945-0232
    Throttle City
    I don't know how mcuh Big Dog specific he's done but I know guys that have been using him for YEARS.
    fiftyonefifty5150 likes this.
  3. wolfen
    wolfen Member
    Mays Landing, NJ
    2005 chopper
    Sean
    Called them ,they said they don`t work on big dogs.
  4. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Sorry
    Hey - He was honest enough to tell you rather then someplaces that would screw the bike up. I knew he was a stand up guy, sorry that didn't help you.
    pknowles likes this.
  5. wolfen
    wolfen Member
    Mays Landing, NJ
    2005 chopper
    Sean
    It`s cool Jersey Big Mike, it was worth a try.
    Thanks
  6. wolfen
    wolfen Member
    Mays Landing, NJ
    2005 chopper
    Sean
    I found a place that said they can Dyno my Chopper. It`s called Screamers Custom Cycles , it`s in Woodbury ,NJ 08096. I`m taking it there tomorrow. I`ll let everyone know how it turns out. If it turns out good , They will be the only place I could find in the tri-state area that has a dyno machine that can do choppers. I`ll let you know.
  7. wolfen
    wolfen Member
    Mays Landing, NJ
    2005 chopper
    Sean
    I got the Chopper back. It put out 117 HP 146 Tq. It has a blip at around 4500 rpms. The guy said it could be a bad ignition switch. It running real good, I normally don`t run it that hard anyway. So I think I will ride it as it is , and slowly look for the electrical glitch. Any advise would be welcomed.
  8. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    What mods have you done to your bike?
  9. KnotSo
    KnotSo Admin
    Washington
    Ever figure out the blip at 4500 rpm's?
  10. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    146 ft. lbs. for a 2005 117 is unbelievable. Literally, unless you have upped the compression, upgraded the valves, 600 cam, Thunderjet and more. I am told the primary can't even handle that torque maxing out at 120 ft. lbs. without bearing support mods.
  11. SEAL-rider
    Del Mar, CA
    Spencer
    Not sure why it took me two weeks to figure this out but I suspect you had 146nm of torque which makes more sense. About 107 ft. lbs.
    Hirter6Pack likes this.
