Magnum steel braided spark plug wires
Discussion in 'General' started by pauldeepsea, Oct 10, 2018.
  1. pauldeepsea
    California
    Paul
    Found these and may be getting a set for the build. Talked to Curtis and he may inquire about seeing about becoming a dealer for them.
    njbiker20088 likes this.
  2. pauldeepsea
    California
    Paul
  3. Th3InfamousI
    Th3InfamousI Administrator
    Texas
    04 Ridgeback & 07 K9
    We kinda need both 90 degree boots. And I looked them up and can't find any, which is odd...
    PacoPetty, pauldeepsea and HMAN like this.
  4. pauldeepsea
    California
    Paul
    After reading on their website they can build them to spec. I plan on calling them to find out if the can do the 90 on both sides of the plug
    PacoPetty likes this.
  5. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    I'd stay away from those. I had issues with a set in the past that gave me all sorts of odd problems. It wasn't until I did some of the 8mm silicone wires that they went away. I can't remember what they're called or what the certain spec is but there's a certain type of plug wire that the bike really needs. Some resistance measure of some kind I think.
    Nukeranger, PacoPetty and francoblay1 like this.
  6. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    RFI suppression.
    Nukeranger and PROFLYER like this.
  7. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    I remember wires called Twisted? I think. They seemed to be ok. I have read that some plug wires won't work very well.
    Nukeranger likes this.
  8. francoblay1
    K9 (2006)
    Franco
    .... It is common knowledge amongst automotive electrical engineers that it is unwise to use ignition wires fitted with grounded braided metal sleeves fitted over ignition cable jackets on an automobile engine. This type of ignition wires forces its cable jackets to become an unsuitable dielectric for a crude capacitor (effect) between the conductor and the braided metal sleeves. While the wires function normally when first fitted, the cable jackets soon break down as a dielectric, and progressively more spark energy is induced from the conductors (though the cable jackets) into the grounded metal sleeves, causing the ignition coil to unnecessarily output more energy to fire both the spark plug gaps and the additional energy lost via the braided metal sleeves. Often this situation leads to ignition coil and control unit overload failures. It should be noted that it is dangerous to use this style of wires if not grounded to the engine with grounding straps, as the outside of the braided cables will be alive with thousands of volts wanting to ground-out to anything (or anybody) nearby....
    https://www.magnecor.com/magnecor1/truth.htm
    I´ve been using the Magnecor R-100 without a problem for many years.
  9. Th3InfamousI
    Texas
    Twisted works if you don't have the EHC or PDM. I had tach issues on my bike with a PDM and just changed to Taylor wires and problem went away.
    I run the twisted wires on my ridgeback though with no problems and that had the WP and ESC. No issues on either unit
    pauldeepsea and PacoPetty like this.
  10. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I had major problems when I put them on my. bike and as soon as I took them off the problems stopped. I loved the way they looked and if they could work out the bugs I would definitely put them back on
    francoblay1 likes this.
  11. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    My bike still has the original EHC.
  12. PacoPetty
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    Franco, this is exactly the problem I had!
    francoblay1 and heybaylor like this.
  13. pauldeepsea
    California
    Paul
    Do you run the stock ehc ?
  14. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    I have Taylor Thundervolt wires on mine, 10mm and red. I think a red set would look sick with your build. I also use the Taylor thundervolt wires on my pickup and wires durango..great wires and good price
    HMAN likes this.
  15. LHS
    LHS Member
    Waterloo iowa
    2009 ridgeback 2004 Honda XR 650 L Dirtbike
    Lew
    Is that metal braiding on there or is that nylon braiding ? If it’s nylon braiding and they can put 90° boots on each end that be awesome. Nice Franco straight facts love it. I put stainless covered braided Ignition wires on my race car one time And spent weeks chasing all kinds of problems. It would not have been so hard to find the problem if I had put on just the wires but I put on a new MSD ignition system complete . Distributor /digital 6AL /new timer step box /coil /all the wiring / etc.etc. Fortunately I f#%ked up one of the wires so I Took the pretty wires off put on a set of Accel 8.8 mm ignition wires I had in the shop and to my surprise the problems went away.
  16. LHS
    LHS Member
    Waterloo iowa
    Lew
    :stupid:
    #16 LHS, Oct 10, 2018
  17. pauldeepsea
    California
    Paul
    Check this out
    https://www.magnumshielding.com/Ignition-Wires
  18. pauldeepsea
    California
    Paul
    After reading I don’t think the braiding is steel
    francoblay1 and chubs like this.
  19. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll, Road Glide
    Carl
    why would anyone put on a set of plug wires that the voltage is looking for a ground path?
    seems like the best ground path is at the plug gap
  20. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    My twisted wires have worked fine on my Ridgeback with Wire Plus.
    I would hope the braided ones aren't steel because I know my wires rub against my Engine Cooling fins!
