Motor noise
Discussion in 'General' started by John Cingel, Jun 1, 2017.
  1. John Cingel
    John Cingel Member
    Parma Ohio
    2008 Mastiff 2011 Stratoliner deluxe
    John
    Just looking do an opinion on this noise. Thanks
    chubs likes this.
  2. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    Its hard to tell through the video, but maybe a broken lifter or valve?
    BadDawg Bill, Alexey and chubs like this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    X2
    dentdude36 and chubs like this.
  4. Fat_Bastard
    Fat_Bastard Active Member
    Route 66
    2004 Big Dog Chopper, HD Fat Boy
    Title: "CRO" , Chief Riding Officer, SoCal riders group
    Agree with above posts but also you may consider:
    cannot be certain... (Sometimes cracked valve spring; compression test to find.)
    Don't know the 2008 Big Dog primary (have the 2004 "harley" primary on mine)
    but yours sounds something like this; but different perhaps because different Big Dog primary setup...
    This video enabled me to diagnose the noise and eventually fix it. -- was a loose Compensator Nut. Compensator noise changes slightly when clutch in and go from neutral to gear and back with out reving motor.
    Reving motor: in gear, or neutral, or riding does it change the noise?
    Also try to stick end of screw driver at suspected area and listen to handle like a
    "stethescope" (no bullshit) to further isolate source area of noise.
    #4 Fat_Bastard, Jun 1, 2017
    BadDawg Bill, Big D Florida and chubs like this.
  5. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Rear cylinder exhaust leak? My hearing is about as bad as my sight tho..
  6. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    :oldcrazy: What??? No glasses on ya can't hear:oldhardlaugh:or see:oldhardlaugh:
    chubs, Alexey and bdm7250 like this.
  7. bdm7250
    bdm7250 Guru
    Doug
    Bdm4ever, BWG56, chubs and 2 others like this.
  8. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Hearing is that bad? That is loud, not an exhaust leak.
    How's your oil pressure? Do you have a manual gauge on it?
    bdm7250, chubs and Alexey like this.
  9. Big D Florida
    Agree with Paul, hard to tell from the video. Diagnostics from the audio would be hit or miss.
    Try to isolate it, internal/external, top-end/low-end, etc.
    BadDawg Bill and chubs like this.
  10. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Yeah that's horrible.. i'd check ur lifters.. sounds almost like one may have collapsed
    chubs likes this.
  11. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Start with the simple things first. A blown or loose compression release, with make a lot of noise too.
  12. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    Pull the primary cover check the easy stuff clutch hub nut or compensator loose.
    Fat_Bastard and chubs like this.
  13. bdm7250
    bdm7250 Guru
    Doug
    Maybe...don't you have a bike on the lift to work on..:willynilly:. :oldlaugh:
    chubs likes this.
  14. John Cingel
    John Cingel Member
    Parma Ohio
    John
    Noise isn't there when I first start it up. It starts once warm. Seems to be coming from the very top on the spark plug side. Listened with a screw driver that all sounds smooth. Its more of a ticking or pinging. I don't have a oil pressure gauge but the idle is high enough .
    chubs likes this.
  15. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    remove the gas cap and check to see if the vent tube down in the hole is still in place or maybe broken off.
    been a lot of people chased their tails trying to find a noise and it just be the tank vent tube.
    chubs likes this.
  16. ground pounder
    ground pounder Active Member
    Ypsilanti,Mi.
    Big dog 2009 K-9 EFI
    Tom
    Did you check your compression relief valves? maybe one is coming apart!
    chubs likes this.
  17. bigglenn
    bigglenn Member
    San Antonio, Texas
    K-9
    Glenn
    Did you ever figure out what the noise was? I have a similar issue with my 08 K9.
    chubs likes this.
  18. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    its not the lower end...I'm going to go with top end as valve train noise, you may have a bad lifter...
    chubs likes this.
  19. sixpack
    sixpack Member
    P'cola, FL
    05 Chopper DT 2010 Bulldog Bagger
    John, I have the exact same noise issue on one of my Dogs. Had the motor rebuilt by S&S and got this issue with the rebuild. S&S has sent me to 3 shops, lifters changed 3 times, same noise. No noise until engine warms up. Pretty frustrating. Let me know if you resolve it. I will do the same.
    chubs likes this.
  20. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    @John Cingel - start with a simple pushrod adjustment and go from there, but the 'stethoscope' trick is your best bet to isolate the noise - screwdriver works fine or harbor freight has an engine one for under $10
    @sixpack - If everything has been done, and the noise continues, check the rocker arm shafts/bushings in the rocker boxes - these sometimes wear out due to heat in both TP Rocker boxes and S&S Rocker boxes and that failure will sound like A ticking as well....
    chubs, Bdm4ever and bigkelk9 like this.
