Need a size between wheel and frame (Ridgeback 2004 only)
Discussion in 'Help Wanted' started by anferumos, Mar 8, 2017.
  1. anferumos
    anferumos Member
    Moscow, Russia
    Big Dog Ridgeback 2004
    Artem
    Hi, guys!
    Help wanted, from ridgeback 2004 owners.
    The problem is that my rear wheel is not in center of the motorcycle axis and stand to the ride side about 5mm.
    Because i placed rear bearings from Harley Touring models (it is easier to find them in Moscow, then original BD). In this case i made some "metall work" in left and right rear wheel hub. So, i think original wheel spacers is not usefull anymore.
    Could anybody sent me a size between wheel (metal part, not rubber) and a frame, like on a photo below (the old photo of my BD, before custom changes)?
    Left and right side.
    Thanks a lot.
    #1 anferumos, Mar 8, 2017
    chubs likes this.
  2. anferumos
    anferumos Member
    Moscow, Russia
    Artem
    Still need sizes)).
    A few minutes in your garage, with ridgeback 2004:rolleyes:.
    chubs likes this.
  3. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Lost in translation? Don't know why you would need that distance, I would imagine it is the same on both sides? If the frame is symmetrical. If you have modified the hub, I suppose you need to measure the thickness of the spacers you need when the wheel is in the middle. Or did I miss something?
    chubs likes this.
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Agreed and if your off 5mm from center than best to measure your current spacers and add 5mm to the side you need you say is off while shaving 5 off the other side. Then all is square? Maybe
    Make sense?
    chubs and TapioK like this.
