New Battery but Bike Wont Turn on!!!
Discussion in 'Technical' started by Jeffrey Leatherwood, Jun 9, 2018.
  1. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Looks like you've been doing some studying.
    Time to start stabbing some wires with a small needle or pin and your Volt ohm meter looking at inputs and outputs.
    Paul G. and Jeffrey Leatherwood like this.
  2. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Jeffrey did you try bypassing your controller yet, that's gonna tell you if it's bad, I believe if you run power directly from the battery to the ignition, then use a jumper wire from the battery to the starter it should fire up, before you do all that check the starter to see if you have a slam button on it, it would be on the end of your solenoid, if you do then you won't need to use the jumper wire, remember before you jump it unplug the green wire from the starter so if your controller is good you don't burn it up, hope that helps.
    #62 cdogg556, Jun 10, 2018
  3. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    I am stumped, are you getting power from the ignition module?
    Longshot but also check the headlight harness, they have been known to melt and could be grounding it out.
  4. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    I am another enthusiastic fan of D O C's EHC. I recall that in your case, you will be dealing with a system that has already been modified with the WP.
    I know many here have Axel's unit and are pleased with it, but I would think in your case, immediate customer support would be important if you encounter issues with the install. You'll not find a smarter or more dedicated product support person than Jeff Moore. As cdogg just said, you wanna install a new EHC, call Jeff. The product is superior, instructions flawless, and the procedures are easily followed. Not at all familiar with what has to happen to replace a WP, but bet your ass Jeff does.
    BWG56, bdm7250, TapioK and 3 others like this.
  5. pauldeepsea
    California
    Paul
    I used to have the wp, the install is as easy as throwing the wp in the trash. Drilling one mounting hole for the unit and routing the wiring through the backbone. Took about an hour to install. Quality product
    bdm7250, pknowles, TapioK and 3 others like this.
  6. dentdude36
    dentdude36 Banned
    Upstate NY (suburbs of Buffalo)
    2007 K9
    kevin
    BWG56 and bdm7250 like this.
  7. roadie1389
    roadie1389 Active Member
    Wylie, Texas
    Any update?
  8. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Check THIS out. :oldthumbsup:
    BWG56 likes this.
  9. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    What do I know but it is questionable to be overly certain the problem and solution is always the same in every case ...
    HMAN likes this.
