NO SPARK - Troubleshooting Tree
Discussion in 'Technical' started by Moespeeds, Mar 29, 2009.
  1. 1BADK9
    1BADK9 Limited Edition Member
    NW Florida
    2007 K9 LE #78
    Brooks
    PM Tim he can make it a sticky, think Ray can too.
  2. germank9
    germank9 Member
    northern Germany - east coast
    k9 2008, zxr 1400
    I've got a ignition problem at my Harley this days. The problem was the cam timing sensor but i'fe searched 2 days for the problem.
    If you have a two wire cam sensor it should be round about 1 k Ohm resistance.
    Mine as round about 1 M Ohm - but - when i connect a multimeter i have had round about 1 V AC - and that should be so said the manual. But the resistance was to high and so the ignition stops some times to work.
    If anyone will have such a Problem with a 2 wire sensor use the restistance for diagnosis - not the voltage when the engine is running like the manual says...
  3. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Start HERE :up:
    "Dos Pajaros de un Tiro!" :D
    #23 francoblay1, Feb 7, 2014
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :roll::roll::2thumbs:
