Noise and vibration when starting
Discussion in 'Help Wanted' started by SEAL-rider, Nov 28, 2017.
  1. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    2005 Chopper - lately when starting I am getting a kind of whine. Now that whine includes a vibration. It starts but does not sound good doing it. Ideas appreciated.
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    make sure your starter hasn't worked it's way loose. should be, i think, 2 screws that hold it to the inner primary housing. but, there might also be 1 from the inside of the housing.
    SEAL-rider likes this.
  3. SEAL-rider
    Del Mar, CA
    Spencer
    That could be an easy fix. Thanks!
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Battery is low?
  5. SEAL-rider
    Del Mar, CA
    Spencer
    I checked the bolts I could access. the motor mounts were good. Getting to the starter bolts requires removing the final drive pulley case. The one I could get too seemed tight. I am in the process of charging the battery with trickle charger but the battery seems strong. I probably won't pull the primary cover and will wait for Curtis to get back and let him sort it out.
  6. SEAL-rider
    Del Mar, CA
    Spencer
    Here is a video with sound.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Video unavailable
    dentdude36 likes this.
  8. SEAL-rider
    Del Mar, CA
    Spencer
    Oops - it was private. Fixed. Could that be pressure release valves or a battery that is not generating enough amps?
  9. Th3InfamousI
    Texas
    Sounds like its engaging okay actually no click click click...
    Could be a bad drive clutch in the starter though.
    Might not hurt to pull the primary cover too and check the clutch hub nut and make sure nothing is binding in there
    Srodden likes this.
  10. shansel88
    shansel88 Member
    Jacksonville FL
    2004 Chopper
    Sam
    Thats no a whine - thats a grind - does this only happen when starter is engaged (button pushed?)
    If so- I would look at
    Starter shaft loose? hitting housing?
    Starter itself -does it do it if on bench?
    If not the starter then it might be the clutch hub nut or clutch bearing - allowing the basket to grind on primary housing??
    Just some on my thoughts - but these are based on the noise only occurring when the start button pressed/started engaged
  11. shansel88
    shansel88 Member
    Jacksonville FL
    2004 Chopper
    Sam
    I actually think what I would do - and everyone has own opinions
    I would take off the primary cover and hit starter and see if you see anything (maybe removing plug wires/plugs so bike doesn't start??
    I would then remove the starter shaft and see if the whine is gone
    - if it is not - then you know its internal to starter
    -If whine is gone with shaft remove then you know the shaft is either hitting something or its the clutch hub nut or bearing allowing the clutch basket to rub - which should be more obvious where noise is coming from at this point anyway.
    Even if hub nut is loose - you may want to consider changing the bearing and cleaning up the drag marks in the primary housing.
    But other opinions on my opinion are welcomed
  12. Th3InfamousI
    Texas
    You will sling oil all over the place unless you somehow cover it...ask me how I know. Second thought, dont! ha
    On your second point of removing the shaft how you gonna do that an start bike? LOL
    Regardless I am with you, not sure its necessary the start.
  13. SEAL-rider
    Del Mar, CA
    Spencer
    Thanks for the great advice. But I am over my head. i will get it to Curtis and let him sort it out. I will report back his findings.
  14. SEAL-rider
    Del Mar, CA
    Spencer
    Yes, it slung oil all over. Even after I dried the bottom of the primary. However the whine was gone. So, I need to find out if the primary case was already like this from previous breakage or if this is new. I suspect it is new wear. If so, and everything seems tight, why would the clutch assembly have moved forward. I did not find any metal shavings in the primary. The clutch seems to still work, at least it moves in and out. Also the bolts done seem worn.
  15. SEAL-rider
    Del Mar, CA
    Spencer
    I am confused. If this is a new condition then something moved. How is a shim going to help? I am asking not questioning the recommendation. Thanks
  16. SEAL-rider
    Del Mar, CA
    Spencer
    The primary chain does not move when I pull in clutch. The clutch assembly seems very tight. I don't have the tool to remove the spring clamp on the outer bearing to get to the clutch nut.
  17. SEAL-rider
    Del Mar, CA
    Spencer
    Just found out that the damage in the pic was previous damage. I might be back to the starter. Ouch.
  18. shansel88
    shansel88 Member
    Jacksonville FL
    2004 Chopper
    Sam
    If you remove primary cover and the whine stopped, then the only thing in the stater that could be an issue is broken shaft - or loose, or something that is hitting the primary cover???
    I'd look at the stater shaft - if not it must be the clutch hub nut or bearing - these are the only pieces that move inside there (that i can really think would cause the noise)- possible starter shaft hit primary cover - or it pushes the clutch basket gear and torques it into the primary cover or even side loads it into the rear primary cover. but to if its the clutch basket moving the nut must be loose or the bearing is bad.
    Either way, my opinion is, if its not the starter shaft broken or hitting primary cover, get a new clutch hub bearing and then as you replace it and torque the clutch hub nut you will have eliminated both possibilities.
  19. SEAL-rider
    Del Mar, CA
    Spencer
    Having done nothing more than removing the primary cover and replacing the rubber gasket and inspection gasket and torquing everything up to WSW specs(thicker gaskets) the noise is gone. Bike started up and ran fine. Now I get to nervously wait for it to happen again or something fail completely.
  20. SEAL-rider
    Del Mar, CA
    Spencer
    Whatever this was, it just went away after I did nothing more than open the primary. Could it be the starter pinion shaft was sticking.
