Noise and vibration when starting
Discussion in 'Help Wanted' started by SEAL-rider, Nov 28, 2017.
  1. SEAL-rider
    SEAL-rider Member
    Del Mar, CA
    2005 Big Dog Chopper 585 cam, John Sachs Super G Carb Thunderjet, V&H Big Radius
    Spencer
    Just found out that the damage in the pic was previous damage. I might be back to the starter. Ouch.
  2. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Well like BWG56 said if it just started and it's not the starter then something must be loose or worn in the clutch hub assembly, I'm sure the tolerances are very close considering the narrow primary cover so check and recheck including eliminating the starter. and report back
    Srodden likes this.
  3. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    I did some more searching on the part number I posted, I had it wrong it's used if having clearance issue between the clutch basket and inner primary which makes better sense
    BWG56 likes this.
  4. shansel88
    shansel88 Member
    Jacksonville FL
    2004 Chopper
    Sam
    If you remove primary cover and the whine stopped, then the only thing in the stater that could be an issue is broken shaft - or loose, or something that is hitting the primary cover???
    I'd look at the stater shaft - if not it must be the clutch hub nut or bearing - these are the only pieces that move inside there (that i can really think would cause the noise)- possible starter shaft hit primary cover - or it pushes the clutch basket gear and torques it into the primary cover or even side loads it into the rear primary cover. but to if its the clutch basket moving the nut must be loose or the bearing is bad.
    Either way, my opinion is, if its not the starter shaft broken or hitting primary cover, get a new clutch hub bearing and then as you replace it and torque the clutch hub nut you will have eliminated both possibilities.
  5. SEAL-rider
    SEAL-rider Member
    Del Mar, CA
    Spencer
    Having done nothing more than removing the primary cover and replacing the rubber gasket and inspection gasket and torquing everything up to WSW specs(thicker gaskets) the noise is gone. Bike started up and ran fine. Now I get to nervously wait for it to happen again or something fail completely.
  6. SEAL-rider
    SEAL-rider Member
    Del Mar, CA
    Spencer
    Whatever this was, it just went away after I did nothing more than open the primary. Could it be the starter pinion shaft was sticking.
  7. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    Absolutely !!!!
  8. Srodden
    Flint, Michigan
    Scott
    Also did you inspect the inside of the primary cover for any gouging or abnormal wear marks ?
    bdm7250 likes this.
