oil running from my tranny in my primary
Discussion in 'General' started by Guillaume, Apr 18, 2017.
  1. Guillaume
    Guillaume Active Member
    Baytown Texas
    K9 2007
    Guillaume
    Well maybe you guy,s have any suggestion for me ,I replace twice my oil seal and still it's leaking from my tranny in my primary.
    I did everything according the drawing from my manual Big dog 2007 K9.
    Put the O ring first and than my oil seal.
    chubs likes this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Did you get the seals from Baker?
    chubs, bdm7250, TapioK and 1 other person like this.
  3. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    I got 20 that says no..
    chubs likes this.
  4. Guillaume
    Baytown Texas
    K9 2007
    Guillaume
    Order from Curtis
    chubs likes this.
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Call him and ask him if they are Baker seals or what he would recommend to fix
    chubs likes this.
  6. shooboy
    shooboy Member
    Rochester, NY
    2003 Big Dog Chopper, 2006 Ironhorse Texas Chopper, 1998 H-D Road King
    Randy
    If you overfill the transmisson with too much fluid it will start producing hydraulic pressure and will blow out the seal. Just sayin', might be an issue. I think it's supposed to be 21 ounces but don't quote me because I'm drinking and watching hockey.....
    chubs likes this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    How can it do that with a vent tube coming out the top?
  8. bdm7250
    bdm7250 Guru
    Doug
    Very close. 20oz
    chubs likes this.
  9. shooboy
    shooboy Member
    Rochester, NY
    Randy
    Just what I heard. Don't remember where but it might have been from my mechanic that replaced the seal on my AIH Texas Chopper
    chubs likes this.
  10. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    I don't know much about what happens to the seal with an overfilled transmission, but one thing I do know is that if you have a bad transmission input bearing, there will be some play in the transmission input shaft that could also damage the seal. But that play in the input shaft results in an extension of the clutch lever when up-shifting through your gears. When you accelerate, the clutch lever wants to push outward because the transmission shaft is actually moving.
    Very bad news, because a transmission rebuild is the only play at that point. When you had it torn down to the inner primary to change the seal, was the input shaft really solid? I'd think that would be harder to detect with the primary chain and clutch all in place....the only movement should be rotation...if the shaft has any play at all, that's a problem.
    chubs likes this.
  11. Guillaume
    Baytown Texas
    K9 2007
    Guillaume
    Thanks
    Well today take of my primary and take off the clutch pack and see if I have playing , but maybe I overfill it .
    Keep you posted on that .
    Guillaume
    chubs likes this.
  12. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I agree with skog. I'd bet your bearings are going and the slop in the input shaft doesn't allow for a tight seal. Doesn't matter what seal you use baker or Harley or one made by god himself if your shaft is moving there isn't anything that will keep the oil in there. Even a little play is too much, you shouldn't be able to move it by hand in any direction.
    It's a common problem on these dogs
    Overfilling it shouldn't do anything it just puke it out the vent tube before it would push it through the seal.
    #12 Th3InfamousI, Apr 18, 2017
    chubs and TapioK like this.
