paint saver/gas cap
Discussion in 'General' started by armad, Aug 18, 2016.
  1. armad
    armad Active Member
    upper midwest
    08 Mutt, 06 Warrior, 99 Roadstar
    Still looking for a gas cap/paint saver combo that does not leak. Tried a new vent mechanism and a rubber gasket, but still leaks. I did a lot of reading here and really didn't find too much for recommendations on a leak free cap. I am going to remove the Landmark paint saver and cap. I do have some paint bubbling, but it is not too bad, but gradually getting worse. Is there anyone out there that has found a vented cap that does not leak? Thanks
    chubs likes this.
  2. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    Do a search for "gas cap/paint saver" and you should get some interesting reading. It has been discussed quite a bit. Good luck
    chubs likes this.
  3. Nཛ͢ཀཇཧ༏ཧי
    Nཛ͢ཀཇཧ༏ཧי ... .... .- .. -.
    Springfield, Missouri
    2007 K-9
    Shain
    Have you tried Mr Wright's paint saver?
    chubs likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    This one vents on top and it evaporates staying off the paint, the vent hole is in one of the indents, the vapors don't turn to liquid under the cap like the OEM one. JP Cycles
    cdogg556, chubs and armad like this.
  5. Razorback
    Razorback Member
    Kansas City, MO
    2010 Bull Dog, 2006 K9
    Greg
    X2 Talk to Shannon, he will be able to fix you up
    chubs likes this.
  6. armad
    armad Active Member
    upper midwest
    Shannon? A vendor on this site?
    chubs likes this.
  7. armad
    armad Active Member
    upper midwest
    Mr Wright and Shannon one of the same? Contact info.
    chubs likes this.
  8. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    I'm here Armad. I'll PM you my number and you can give me a call.
  9. armad
    armad Active Member
    upper midwest
    I did the search, but didn't see any recommendations. Could have missed it, but now I have been hooked up with Mr. Wright. Thanks
    chubs likes this.
  10. armad
    armad Active Member
    upper midwest
    Thanks, I will check this out. Did it stop the paint bubbling too?
    chubs likes this.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :yesnod: so far:old2:
    cdogg556 likes this.
  12. bigdog1rm
    bigdog1rm Member
    San Antonio,Texas
    2008 K9 EFI
    Ronnie
    Shannon is the man i have mine on for a little over a year and no problems.
    chubs likes this.
  13. aspen874
    aspen874 Well-Known Member
    Saint Louis, MO
    07 Mastiff 2010 Bulldog Bagger
    Stephen
    I put one from Shannon on my buddies K9, works great and looks good.
    chubs likes this.
  14. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    How'd does that bad boy go on? Those Allen heads are just for looks right? I'm assuming it's a pop up deal? Looks bitchin!
    cdogg556 and chubs like this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    It screws in just like the paint saver does, you remove 2 of the screws and insert the brass standoff's to tighten it and then remove them and reinsert the screws, the screws do not touch the tank and you can see the cap screws off with the black part in the pic. J&P Part: 633-887
  16. bigkelk9
    07 big dog k9
    Kel
    Sweet and you got that from JP CYCLES
    chubs likes this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Yes :yesnod:J&P Part: 633-887 venting
    chubs likes this.
  18. pknowles
    virginia
    paul
    Did you set it in epoxy or anything. That looks good.
    chubs likes this.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Hell no, I had my fill of epoxy, I tried putting chemical resistant epoxy on around the edge of the paint on the bare tank and the gas made it gummy even after I left it set for 3 days before installing. So all I did was to remove the gummy epoxy and sealed the paint edge with a few layers of clear and installed it with the rubber gasket that came with the cap.
    You can see the vent hole in the cap, the brass screw is pointing at the vent hole in the cap and since that is recessed into the paint savor when the cap is in place, the vapors evaporate. With the OEM cap, every time I put gas in it, I could see the liquid under the cap which eventually wicked around under the paint savor.
    That's my story and I'm sticking to it.:D
    TapioK likes this.
  20. armad
    armad Active Member
    upper midwest
    I removed the paint saver today. It went good and came out easily. Only problem was I had to cut back more than I would like to get rid of the bubbled paint. There seemed to be some filler up by the opening. I will have to seal this up somehow. It ended up being about 2 3/4 in. across. I ordered the Kuryakn flush cap 8309, I hope it will cover the whole area.
    chubs likes this.
