Paint Saver removal Tool
Discussion in 'General' started by Ridgeback9040, Apr 14, 2019.
  1. Ridgeback9040
    Ridgeback9040 Member
    South Florida
    2008 Ridgeback
    Ridgeback330
    I got the paint saver ring from Mr Wright and getting ready to do the job , missing only the removal tool , read forum has 1 running around ...
    Can someone let me know if you have 1 available?
    Thanks in advance
  2. knothead
    knothead RIGID4LIFE
    Tennessee
    2 2004 big dog ridgebacks
    knothead
  3. Ridgeback9040
    South Florida
    2008 Ridgeback
    Ridgeback330
    Thank you , I was hoping to borrow one from someone that’s not using it , I guess I will have to buy one as well ....
  4. Unsprung
    Ruskin, FL
    Gerald
    Give it a chance to see if someone comes along and reads this who has one. Most of these guys are a good bunch and won’t mind helping you out.
  5. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    :agree: A few years back I got one sent from the US to Spain!!! :old2:
    :chopper:
    Unsprung likes this.
  6. Ridgeback9040
    South Florida
    2008 Ridgeback
    Ridgeback330
    Thank you guys !!
    Hopefully someone has one ...
  7. bigdog1rm
    bigdog1rm Member
    San Antonio,Texas
    2008 K9 EFI
    Ronnie
    You can use a big bolt that threads in the hole and put a nut on and lock it down and put a 3/4 Ratchet on the bolt head and twist it out.
    TapioK and francoblay1 like this.
  8. Ridgeback9040
    South Florida
    2008 Ridgeback
    Ridgeback330
    I will have to use the same ring and cap , won’t that damage it or it would twist out easily with some torque ??
  9. Ridgeback9040
    South Florida
    2008 Ridgeback
    Ridgeback330
    Worse come to worst I just buy the right tool ... and then I would send it to whoever needs it
  10. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    I believe I have it... just made a few moves and finally settling in, but lemme check
  11. Ridgeback9040
    South Florida
    2008 Ridgeback
    Ridgeback330
    That would be great ! Just let me know
  12. bigdog1rm
    bigdog1rm Member
    San Antonio,Texas
    2008 K9 EFI
    Ronnie
    I tried the tool could not get it out on mine. I forgot to say use a washer and tape it up after you put the nut on the bolt then thread it in the bung and lock the nut down and then i use a 3/4 inch ratchet with the correct size socket to fit the bolt. Mine came out really easy.
    pknowles likes this.
  13. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    There was one guy on here that tried beating his out with a hammer and a chisel.
    Dont think it ended well:oldhardlaugh:
    chubs and brob like this.
