Popping way bad on deceleration
Discussion in 'Technical' started by JayJay, Jul 11, 2017.
  1. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
    im up against the ropes on this one. 07 k9, 117 motor, Vance and Hines big radious pipes. Word is mixture needle should be out 11/4 to 1/12 ball park. I noticed mine is out almost 3 turns. I do notice raw fuel in the exhaust when I first get it out of the garage, but it runs very nice. Problem is when I bring the needle in closer to text book settings, bike pops and cracks terrible on deceleration. Carb is jetted correctly with a 32 mid jet, and I've done the intake leak test useing carb cleaner. Doesn't seem to have any. Any help would be great. Also are these pipes known to be bad for that. I'm assuming I'm running it really rich just to stop the decel pop !
    chubs and bigkelk9 like this.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Not running baffles? How's the plugs?
    I don't know my bikes all pop on decel, but I don't run baffles so I just don't loose sleep over it.
    HMAN, JayJay, chubs and 1 other person like this.
  3. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    My bike pops on decel and on shifting gears.. pretty common if u don't run baffles. A buddies bike who's is the same as mine with baffles doesn't pop.. So go from there..
    JayJay and Big D Florida like this.
  4. bigkelk9
    07 big dog k9
    Kel
    By the way, one is an 06 and the other is an 07 k9, both have big radius pipes, one with baffles don't pop, the one without pops..
  5. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    And there you go!
  6. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
    Good info, I guess I'm making more of it than it is, I guess run her a little fat or let her pop !
    Not running baffles definetly seems to play a big part. Thanks guys.
    chubs likes this.
  7. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback
    Kurt
    Three turns out on the mixture and raw fuel in the exhaust would indicate you have issues. Are you three turns out to have a nice idle, or to reduce the popping? How do you see the raw fuel in the exhaust and where?
    chubs likes this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Read this maybe it will help
    chubs and JayJay like this.
  9. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff, R80st.
    Paul
    And while you at it, put new mixture screw in. They do wear out.
    Also check your exhaust gaskets for leaks.
    Paul.
    francoblay1, chubs and BWG56 like this.
  10. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
    3 turns out to stop the popping, it will run fine tunning per s&s instruction, just pops on decel like crazy there. Bike has been like this since the 640 lift cam install. When I say raw fuel I mean you can smell it in the exhaust only when it is cold. Once warmed up you don't notice it. Also exhaust gaskets and such seem to be just fine.
  11. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I run a 78 main and a 32 idle, air mixture screw out 2 3/4 turns, baffles cut in half, no popping at all and still loud as hell and faster with the half baffles in then without.
    chubs likes this.
  12. Fat_Bastard
    Fat_Bastard Active Member
    Route 66
    2004 Big Dog Chopper, HD Fat Boy
    Title: "CRO" , Chief Riding Officer, SoCal riders group
    Sometimes popping on decel is a sign it is running a little lean on the bottom end...
    Richen it up to see if it goes away,
    Best way is to temporarily test for a few seconds on DECEL ONLY by:
    Ride it around after warmed up (5 minutes) put it into a closed throttle decel from say 2nd or 3rd gear for a good distance from mid level to high RPM and as soon as you let off the throttle pull up a little on the choke lever to create a richer condition, bring it down to about a thousand RPM; if this stops the popping then you know what to do -- go richer on the bottom end... (air screw, pilot jet, etc.).
    PS: Check your air cleaner for holes, gaps incorrect seal too.
    chubs and cdogg556 like this.
  13. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
    Yours seems to be on about the same settings as mine, which mine doesn't pop and go on at 23/4 eather, so maybe running on the rich side is ok, just enjoy and stop fretting about the needles setting not being text book.
  14. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    What’s your elevation? I’m at about 5500 and had similar issues. Or did you get it straightened out?
  15. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
    Elevation 978, still have the problem, replaced the needle, rebuilt the carb. Still have to run rich.
  16. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Gotcha. I went and got new pipes in hope that’ll help too.
  17. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
    I was thinking the same, let me know the results of the pipe change.
  18. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Did you play with air mixture screw? I can make popping or not just by turning it a bit richer or leaner...
    francoblay1 likes this.
  19. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Big D Florida likes this.
  20. JayJay
    JayJay New Member
    Stanton, KY
    K9
    Jay
