Popping way bad on deceleration
JayJay
Yes mine is the same, problem is I’m way rich when I go out far enough to stop the deceleration popping.
Twisted
The slightest bit of back pressure helps a lot. Look into Big City Thunder baffles or what I did was weld a washer to a bolt and mounted it inside the pipe, about an inch or 2 from the end with the washer centered in the pipe. Still loud as hell but doesn't pop nearly as bad now.
Unsprung
In the Potters hand...
Did the same thing on my 03 Pit and it worked for me. Easy and cheap to make, check out exhaust popsicles.
