Primary Case Cover Drain Plug
Discussion in 'Technical' started by Ernie12, Jun 21, 2018.
  1. Ernie12
    Ernie12 Active Member
    Ohio
    02 BD Pro Sport
    Ernie
    Is the drain plug in the primary case supposed to use a star or hex? I am thinking the previous owner stripped out the old plug and replaced it. This one does not want to tighten very tight so I stopped. It also had some kind of sealer around it when I took it out.
  2. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    Mines a hex. I put a few wraps of teflon tape on it.
    pknowles likes this.
  3. Ernie12
    Ohio
    02 BD Pro Sport
    Ernie
    I thought it was strange that it had a star plug when everything else is hex. I put some Liquid Teflon on the threads so I hope it doesn't leak.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Mine is hex
  5. SEAL-rider
    Del Mar, CA
    Spencer
    No pressure in the primary, only gravity so it should be fine.
    Ernie12 likes this.
  6. Ernie12
    Ohio
    02 BD Pro Sport
    Ernie
    Thanks, I did not know that!
  7. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    The manual says 4 ft lbs torque. If you don't have both inch pounds and ft pounds torque wrenches, you should buy or borrow some. And check with Broadband to download manuals so you can followstep by step directions. It is important to follow procedures with these bikes. That includes torque values.
    Until you have solid direction from manuals,it is good to keep asking Q's. But you really ned to get the manual downloaded so you can learn what general procedures to follow.
    what? and pknowles like this.
  8. Ernie12
    Ohio
    02 BD Pro Sport
    Ernie
  9. Ernie12
    Ohio
    02 BD Pro Sport
    Ernie
    Also I thought that torque of 120inch pounds seemed pretty high so I was pretty cautious when turning it and stopped when it never showed signs of tightening. Clearly the previous owner over tightened it.
    BTW I do appreciate all of the help answering my questions. It would be a lot tougher without this place so Thank You all.
    pknowles, chubs and Reddickracing like this.
  10. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    chubs likes this.
