Purchased a 04 BD chopper less than a day ago and left me walking
Discussion in 'Technical' started by Chopperadam, May 26, 2018.
  1. Reddickracing
    Reddickracing Active Member
    Full Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    SUNPIE Daymaker on Amazon. Several have it including myself and I love it Day maker.jpg
    Hirter6Pack and Unsprung like this.
  2. Big D Florida
    Full Member Supporting Member Troop Supporter
    When applying dialectic grease or any no-oxide compound, a light coat is reccomended, I have seen DC connections insulated by excess grease, perform poorly under load.
    As far as your battery... you never know how it was handled prior to purchase, motorcycle wet-cell battery plates are thin and fragile by comparison to that of a car battery, and damage can occur in shipping & handling.
    Load testing is free at most automotive part stores.
    #22 Big D Florida, May 26, 2018
  3. pknowles
    virginia
    paul
  4. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    Ok, dentdude36 do you have paypal? I’ll prolly do that being led it should draw less current and run a lot cooler! Thanks !
  5. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    I’m headed to town to try and pick up a cam sensor locally and have the batt with me to get load tested I’ll let you guys know what I come up with!!!
    Reddickracing and Big D Florida like this.
  6. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    Well I luck with cam sensor locally. And dropped the battery off at interstate going back in a hour. The cca on the battery is 310
  7. Big D Florida
    Just got
    330 cca is recommended.
    When the battery is a little down on my bikes, they will crank, but not start.
    There are a lot of differing opinions on brand, and tons of threads on the subject.
    I would advise considering an upgrade.
    :2cents:
  8. Unsprung
    Full Member
    Ruskin, FL
    Gerald
    When I purchased my dog it had a 7 year old Deka that still cranked the engine. I replaced it for peace of mind with the same battery. I believe they are 310cca and they are good batteries priced right.
    Big D Florida and pknowles like this.
  9. Big D Florida
    That's pretty good for a battery that old, the vibration really reaks havoc on the plates, and there is little space in the bottom of the cases for the lead sulfate buildup that shorts the plates at the bottom.
    I feel lucky if I get 5-yrs out of one, even in my Harley.
    #29 Big D Florida, May 26, 2018
    chubs likes this.
  10. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    So I cleaned up the cam sensor with some break cleaner there was some residue on it prolly oil. there was just a little bit of oil in the housing I took care of with a q tip Put back together and no luck but figured it was worth a shot. I’m going to order the sensor off amazon. Won’t get it til middle to late next week. Local Harley shop told me that’s old and Harley don’t make them anymore he can’t even order it jack off I don’t believe him. I still get the tea light in the ignition module but it don’t blink when I’m cranking. I started it this morning then took the battery out and had it checked out. Got back home put battery back in wouldn’t fire them cleaned cam sensor still no fire. I’m really hoping new cam sensor fixes it
    Big D Florida likes this.
  11. liferider
    liferider Guru
    Full Member
    Louisiana
    Jonathan
    Whom ever your mechanic is....run, run away fast from this person!!!!!!!!
    #1. Where do you live? We have ton’s of people here who can hook you up with a mechanic who can fix the problem correctly. Not adding to the issue with a bigger problem!!!
    Matheny 514 and chubs like this.
  12. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    :agree: I'm about 3 hours from you.
  13. liferider
    liferider Guru
    Full Member
    Louisiana
    Jonathan
    Chopper Adam, mr Wright just offered you the Holy Grail. I suggest you PM him!!!!
  14. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    Sorry guys got held up with family yesterday. MR. Wright as soon a I figure out how to pm you I will brother !!
  15. liferider
    liferider Guru
    Full Member
    Louisiana
    Jonathan
    Look at Mr Wright’s input. Click on his name. This will bring his personal up. Then click on start conversation
    Big D Florida, Unsprung and chubs like this.
  16. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
  17. SB03chopper
    SB03chopper Active Member
    St. Louis, Mo.
    2003 Big Dog chopper, 2004 Honda 1800 R vtx
    Steve
    Okay now you meet a lot of the people from here if you join us in Kansas in June. Glad you got the Chopper, I know you are going to love it. And Mr. Wright is the go to guy for help, and knowledge!
  18. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    What day in June? Sounds like a good time what’s it all about?
  19. Chopperadam
    Chopperadam Member
    LaGrange mo
    04 bigdog chopper
    Adam
    Update I got ahold of mr. Wright. And when I called him of course the bike starts right up no issue lol but he was very patient with me talked me through testing the cam sensor and tested good. So I have a two mile long black top side road in front of my house I rode back and forth giving her hell hitting bumps then going slow riding easy back to letting her eat and no issues did that for close to a hour. Parked it took a nap went went about 10 more miles and still running good!’
    Mr. Wright likes this.
  20. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
