Ed U. Cator
Higher Ed.
RE: 2006 Mastiff S&S 117 6spd Baker
I changed transmission oil last week using BelRay 80W hypoid GL-5 and it seems to shift a "little bit" harder than before. BelRay bottle doesn't state that it's synthetic. My owner's manual clearly states do not use synthetic oil but use a high quality 75W/140. I visited Baker Drivetrain website and under SUPPORT there's a BigDog section that lists both Spectro & Redline 75W/140 as full synthetic which apparently they recommend for the BD transmission. So which do I go with? Synthetic or follow the operator's manual using non-synthetic. Why is it everything I own has conflicts involved when it comes to simple maintenance & repair? Sheesh!
Furthermore the owner's manual states fill 1 qt. oil in the primary case, yet the primary case has 1.5 qts. stamped on it so I went with what's stamped on the case 1.5 qts. -- of non-synthetic 20w/50 wet clutch support dino-oil. Any preferred brands of that type?
