Rear shocks for 2002 Prosport
Discussion in 'Help Wanted' started by WYprosport, Feb 13, 2018.
  1. WYprosport
    WYprosport New Member
    WY
    2002 Big Dog Prosport
    Jared
    I am wondering if anyone has found a replacement set of shocks for the rear of the Prosport? The Originals were made by Works and they are out of business. Mine are leaking all over the place. I really like the look and the reviews of the Progressive 412's, but I cannot find which model I need. I called tech support line at Progressive and they told me they cannot help me unless they know the spring rate of the old shocks. They asked me to disassemble the old ones which I did, but there are no markings. The tech then suggested I call Big Dog and ask them, I did but haven't heard back from them. The shock is 13" eye to eye. Anyone have any suggestions?
  2. pknowles
    virginia
    paul
    You have the measurement that you need. Most are adjustable for the weight. Shouldn't be too hard to get a set to work. Post up a picture of the old ones.
  3. WYprosport
    WY
    Jared
  4. WYprosport
    WY
    Jared
  5. WYprosport
    WY
    Jared
    I posted a couple pics. I didn't think it would be that difficult either but according to a few people at Progressive, it's not as easy as just picking a length and an offset (mine has none), but they need spring rate and a few other items, but they said spring rate was most important.
  6. pknowles
    virginia
    paul
    You would think a set for something like a dyna would be about the same ??
    WYprosport likes this.
  7. liferider
    liferider Guru
    Louisiana
    Jonathan
    Progressive 412
  8. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I expect the big question is weight the Harley closest to your Dogs weight would be the best choice.
    Progressive never tested any on Big Dogs why they won't recommend anything, they don't want that liability. Same issue with their fork springs they don't want to recommend.
  9. liferider
    liferider Guru
    Louisiana
    Jonathan
    I have progressives on both my bikes. Both heavy duty ones. I’m 235lb .
  10. WYprosport
    WY
    Jared
    Thanks all for the suggestions. I called JP Cycles and got a really helpful guy there and he had some specs on them, he said the 99-00 HD FXR was the same style and I ended up ordering
    J&P Part: 701-746 for the Progressive 412's Heavy Duty
  11. liferider
    liferider Guru
    Louisiana
    Jonathan
    Cough cough!!!!!!!!!!YOUR WELCOME!!!!!!
  12. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll, Road Glide
    Carl
    Guess I'm lucky , haven't had any problems with my 01 Pitbull
    pknowles likes this.
  13. pknowles
    virginia
    paul
    Lucky you still have a backbone:)
  14. liferider
    liferider Guru
    Louisiana
    Jonathan
    Progressive also has rebuilt kits for your forks
  15. WYprosport
    WY
    Jared
    Yes that's what they ended up with they said the set off the FXR (SuperGlide) would be the same. Thanks for the direction on this.
  16. heybaylor
    East Texas
    Carl
    well, when they need it I will rebuild them, so far just taking them apart/cleaning/replacing fluid has worked pretty good .:whoop:
  17. heybaylor
    East Texas
    Carl
    barely, but watching for potholes helps .....lol
    Rottweiler and pknowles like this.
  18. KnotSo
    KnotSo Admin
    Washington
    You could find a local shock guy, take the bike with you and they can set you up perfectly, or rebuild what you have.
