Replacing Stator
Discussion in 'How-To' started by Pitbu1l, Jul 24, 2012.
  1. grizfish
    grizfish Active Member
    SoCal
    03 BD Chopper (all orig), 72 HD (a few orig parts)
    Joe
    francoblay1 likes this.
  2. prairiehorse
    prairiehorse Active Member
    montana
    05 Ridgeback
    This write up is awesome but i cannot see the pix? What am i doing wrong? Just shows a broken page for the pix
  3. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Your doing nothing wrong! When the site was revamped we lost a lot of pics to the how-tos...
  4. prairiehorse
    montana
    05 Ridgeback
  5. cd24747
    cd24747 Active Member
    Camillus N.Y.
    2008 Texas Chopper previously 2003 Texas chopper Harley fat boy and sportster 1200
    Domo
    Reaaaaalllly old bump but is there any way that you can repost the pictures. I’ve gotta do this project again.
  6. Th3InfamousI
    Th3InfamousI Administrator
    Texas
    04 Ridgeback & 07 K9
    Unfortunately this is a very old thread back in 2012 and with multiple forum upgrades and the PhotoBucket 3rd party issue we lost quite a few of these.
    Overall the stator job is pretty easy and the write-up if you follow along will be pretty self explanatory once you open it up. However, is there any particular picture you are looking for? I just replaced mine recently so have pics but not broke down like the above.
  7. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Eric, did you go 40amp? I’m just trying to figure why. To my understanding our battery can charge at max 30 Amp, and we have no huge stereos etc on bike to eat Amps...
  8. Th3InfamousI
    Texas
    No I didn't go with the 40 it's almost 2x the price.
    I agree it's not really needed on our bikes, however it does charge at 14.4v at idle whereas the 32 does not. Minor detail.
    The one caveat for the 40amp is heated gear, which is nice to have on long hauls. I am an idiot and didn't bring the jacket with me on my last trip and I paid for it on a few early mornings just makes it much more comfortable. Anyways, my jacket and gloves draw about 8amps on High which is still fine for 32 but If you have a passenger with heated gear it might be worthwhile to go 40.
    Also, if you go with the compufire doesn't matter if it's 32 or 40 you'll need to grind down the bosses on the inner primary to get the rotor to fit.
    francoblay1 and TapioK like this.
  9. Ernie12
    Ernie12 Active Member
    Ohio
    02 BD Pro Sport for sale, 08 K9
    Ernie
  10. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
  11. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Depends on the year if you have to grind them down -- I've done 2 08 K-9's to the CompuFire 40A nad neither required any grinding.
    I went 40A since I am thinking about heated gear and some add-on electronics and I love that it charges at idle.
    Overkill but that's how I roll sometimes -- go big or stay home!
  12. Th3InfamousI
    Texas
    did you happen to take the inner primary off when you did the install? I did that on one install and it does fit and I ran it for about 10k miles but down the road I couldn't get the rotor off with just the primary cover because of how tight it was magnetized and you have to kinda of wiggle it off with the teeth. On is fine, off is hard
  13. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    I did not take my inner off.
    Kinda wish I had and replaced seals because I have since developed a small nagging leak.
  14. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    There are threaded hole in the rotor that you can put bolts in and use them as a puller.
    The bolts are different sizes for Compufire and Stock big Dog.
    I had the inner off the last time, only beacuse I was replacing the transmission as well.
    My charging system was OK, I just figured now was the time to do an upgraded that I wanted. (since it was apart already.)
  15. cd24747
    Camillus N.Y.
    Domo
    I can not for the life of me figure out how to get the rotor off so I can get to the stator. Any ideas?
  16. Th3InfamousI
    Texas
    Put threaded bolts in the rotor holes and just pull it off
    Jwooky likes this.
  17. lowrider47
    lowrider47 Pooch
    marshall minnesota
    big dog chopper, fxr lowrider, sportster
    marti
    Good write-up, I did mine two years ago and yes step #6 can drive you crazy! I forgot my hex screw and just about wrecked my plug trying to get it out.
  18. Big Kev
    Big Kev Member
    Newport News, Va
    2006 Mastiff
    Kevin
    I can’t see the pics either, I can see where the pics supposed to be. I understand there were upgrades causing old images not to be able to be viewed from older posts but I get the same [IMG] thing when trying to check out the Ass & Tits of the Day pics and that’s just unacceptable!!
    Any possible fix?
  19. cd24747
    Camillus N.Y.
    Domo
    Got the new stator and voltage regulator in. Bike is back together... starts with a jump but still not charging the battery. Any thoughts?
  20. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
