Replacing Stator
Discussion in 'How-To' started by Pitbu1l, Jul 24, 2012.
  1. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    If you know how to solder properly
    Jwooky and chubs like this.
  2. cd24747
    cd24747 Active Member
    Camillus N.Y.
    2008 Texas Chopper previously 2003 Texas chopper Harley fat boy and sportster 1200
    Domo
    It is charging now but it’s low voltage. Lingering around 12.5 volts. Should be around 14 I believe?
  3. Th3InfamousI
    Th3InfamousI Administrator
    Texas
    04 Ridgeback & 07 K9
    14 is where it should be, but it might be 12.5 at idle. If you give it some throttle does it go up?
    And Just to confirm because obviously there's been missing info, this 12.5 you are measuring directly at the battery?
    1) What is battery voltage when bike is not running?
    2) what is battery voltage when bike is running at 2k RPM?
    Jwooky likes this.
  4. cd24747
    Camillus N.Y.
    Domo
    After stopping and starting it several times it’s now charging st 12.3ish but when I shut it off the battery goes up to 12.5.
  5. Th3InfamousI
    Texas
    12.3v is if you have it at 2k RPM?
    If that's the case then it's not charging at all, and it goes back up to 12.5 because you removed the load when it's running from lights, speedo, ignition, etc it's not much but would fit the bill.
    In that case you need to work your way back and find the VR wire to the battery and make sure your VR wire is hooked up Correctly to a breaker or a fuse (pics will help) and check that breaker or fuse isn't faulty then proceed back to your crimp job or could be rubbed elsewhere along the frame rail. The problem most likely lies in that line (and the wire from VR should be black with a fairly thick rubber coating)
    You appear to be receiving AC voltage out of the stator? If measured correctly based on above and chances are the VR wasn't faulty out of the box. So problem is in that line somewhere.
    Jwooky and TapioK like this.
  6. cd24747
    Camillus N.Y.
    Domo
    I’ll probably do that this weekend. I was hoping to be riding but it looks like once again my Saturday will he spent working on the horse... should’ve gotten a Big Dog...
    xonionx likes this.
  7. TapioK
    Tapio
    Both have similar charging system don’t beat a good horse. Even in worst case it’s just faulty $80 VR since it seems the stator pushes good voltage 20+ in idle and 40-60 in higher voltage. What happens, or is it even possible to connect wires from stator to VR wrong way? Would it fuck all the electronics on the bike?
    xonionx likes this.
  8. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    All good advise^^
    Assuming you are getting ~20VAC out of stator
    Then there is an issue with one or more of the following
    1) There is an issue with VR
    2) The CB/fuse in the charge circuit
    3) Its wired incorrectly
    All relatively easy fixes. you should be on the road within an hour
    xonionx likes this.
  9. cd24747
    Camillus N.Y.
    Domo
    CB fuse in the charge circuit? Not gonna lie... don’t know that that is...
    xonionx and pknowles like this.
  10. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    If you cut the wire between the reg and the battery, you have no choice but to replace the reg. If you splice that wire, you will have nothing but trouble.
    xonionx likes this.
  11. cd24747
    Camillus N.Y.
    Domo
    Any thoughts
  12. Th3InfamousI
    Texas
    You must not be reading the entire post people are putting out there, I mentioned it in mine and some other folks had already mentioned it. The devil is in the details....good luck!
    Jwooky likes this.
  13. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    CB=Circuit Breaker
  14. cd24747
    Camillus N.Y.
    Domo
    I’ve read it all several times.... just didn’t put 2 and 2 together. No one ever accused me of being smart
    pknowles likes this.
  15. speedball jr.
    speedball jr. Member
    Breaker Breaker
  16. cd24747
    Camillus N.Y.
    Domo
    New voltage regulator is on the way... now it’s giving me a hard time going into neutral...
  17. cd24747
    Camillus N.Y.
    Domo
    Still tough getting it in to neutral but the new voltage regulator brings the charging up to around 14.2... thanks guys!!!
    Jwooky, TapioK and Rottweiler like this.
  18. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    Glad to hear it is now charging. :oldthumbsup:
    cd24747 likes this.
  19. Th3InfamousI
    Texas
    Haha, well you'll know for next time not to splice that wire!
    However, really splicing any wire on a motorcycle is just opening up a potential issue down the road. It's worth the time and money to just replace it entirely rather than dealing with it later when your probably on the road!
    cd24747 likes this.
